05-15-2010, 18:48 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: some where in india
Member: 350232 Status: Offline Thanks Meter: 207 | mx-key error solved try this I have found the solution for server problem in MobileEx v 3.4 1. Uninstall al the previous versions including v 3.4 2. Delete manually The directory c: mobileEx 3.x. 3. Search in c drive for mobileex*.* 4. Delete all the files. 5. Install mobileEx 3.4 again. 6. sign application. 7. You are ready to go. And getting ERROR: request failed! - You will solve the problem by doing the following. The error is because the software is defaulting to a blade host which is down. Luckily there are now 4 hosts, so you need to do the following to change the host address manually. Reinstalling MobileEx does not solve this issue! 1. Close MobileEx 2. Go to C:\mobileEx\3.4 or wherever you installed the software 3. Open mobileEx.XML in Notepad (Right click Open With) 4. Change the following <blade host.1="host1.mxkey.biz"/> to <blade host.1="host2.mxkey.biz"/> (you can also use host3 or host4) 4. Save the file, open mobileEx and cross your fingers. I hope this helps all that are stuck with this issue. this solution is not made by me |
05-18-2010, 10:14 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
http://forum.gsmhosting.com/vbb/f550...swered-999587/ | |
05-18-2010, 10:33 | #3 (permalink) |
Freak Poster Join Date: Feb 2010 Location: india (telangana state) Age: 46
Member: 1230663 Status: Offline Sonork: 100.1593487 Thanks Meter: 174 | delele xml file and sing up again problem solve.then shows server list |
The Following User Says Thank You to .::VENUGOPAL::. For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
