Old 01-17-2010, 13:16   #1 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
Thanks Meter: 362
Thumbs up Solution ''Sign Apllication'' For AMD Prossesor! 100% working
Problem
u want sign application and u get only this msg !!
Starting application sign request ...
Connecting server [ca.mxkey.biz] OK, Secure Login ...
Solution
Sign application in intel PC then copy mobileEX.xml from C:\mobileEx\3.3 and past in other AMD PC where not work singing application in C:\mobileEx\3.3 and the software will working without request sign application
br
www.gem-flash.com
The Following 8 Users Say Thank You to DARIFBS For This Useful Post:
Old 01-17-2010, 13:24   #2 (permalink)
Member: 63120
Thanks Meter: 58
is 50% solution
after this way sign trick, sever not can be founded on amd pc, sx4 not work, online unlocking not works.....
so , nothing get after sign on other intel PC
br.skkeptik
Old 01-17-2010, 13:26   #3 (permalink)
DARIFBS's Avatar
Member: 537213
Sonork: 100.1577391
Thanks Meter: 362
br.skkeptik
exactly that's just fix problem sign application waiting full solution from mxkey team.
The Following User Says Thank You to DARIFBS For This Useful Post:
Old 01-17-2010, 13:31   #4 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
Thanks Meter: 59
its only 50% solutions but thanks bro...
Old 01-17-2010, 13:43   #5 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
@All be patience please...
I think not have "something" with AMD Athlon processor ...
Look here : http://forum.gsmhosting.com/vbb/showthread.php?t=888606
So the poll is closed, mean mxkey team have solution already ...
thanks
Old 01-17-2010, 15:36   #6 (permalink)
Member: 145289
Thanks Meter: 35
In my amd laptop mx-key works without any trick...
The Following User Says Thank You to hakkothebest For This Useful Post:
Old 01-17-2010, 18:51   #7 (permalink)
Member: 63120
Thanks Meter: 58
heeeeeh is not so shure
please post here log of unlock any phone , or check servers status on 3.3 1.1
on amd processor,
easy clone sign file from intel, but is not usable for unlocks......
simple, codder not make good job in comunication after 3.2 , after that version always problem with serbvers unlocking or sx4, so codder must cjeck code again, or give chace to us to find a bug in commmunication. i found a way to mix modules and exes , 3.2 ols shell, with new module, but not have phone to test it . please Alim........ fix this **** , many of us use amd , personaly i have 2 amd-s and 3 intel, but all nokia stuff is on sempron, and other boxes not have any problems. recompile exe on amd platform, or check communication protocols, bug is stupid , and not exist in 3.2 . as Manole say , you warned about this bug before new year, and you doo nothing. for example. 3.2 version online unlock 6220 easy , and 3.3 1.0 , not make codes with server.......
and some other phones.
br. skkeptik
The Following User Says Thank You to skkeptik2 For This Useful Post:
Old 01-17-2010, 19:30   #8 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
i have same problem but i solved it , just remove mxkey and plug it again at the teme of Starting application signing request
enjoy
Old 01-17-2010, 21:27   #9 (permalink)
Member: 63120
Thanks Meter: 58
dongle plug.unplug
Man, this is cheap tool, but not a toy, if you just unplug and plug dongle, it means you not see dongle before ....... or pc ask you for new drivers.all that is not important if you see serial number in software, problem is communication part of main exe, it must be rewriten, becouse is based on st... routine that not 100% compatible with amd chipset.that i sreason why not work sx4 or online unlock after trick to sign soft on intel platform.
br. SKKEPTIK
please corect me with prove if i im in wrong...... paste here log online unlocking and picture of device manager with type of CPU. so maybe only chipset, is problem not cpu, if amd on some laptops works , on some chipset , i can confirm no one nforce chipset with any amd cpu not sign and not comunicate with serverin any way, maybe integrated nvidia controler lan or wireless are probelm ?
i suppose must of us use cable conections......
so CPU or Chipset is reasona why not sign our application. Tomorow , i will ty intel on nvidia chipset , and post here result.
Old 01-17-2010, 23:08   #10 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 459
mx-key team please fix this bug - many users have same problems!!! Are you sleeping ?!?!!?
Old 01-18-2010, 04:05   #11 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Can you connect to server or do SX4 auth, screenshoot please
thanks
Old 01-18-2010, 04:30   #12 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
it's work with AMD sempron....
Old 01-18-2010, 04:58   #13 (permalink)
Registered User
Member: 404911
Thanks Meter: 33
what about in AMD athlon 64 x2....?
anybody have succes in this processor??
Old 01-18-2010, 05:56   #14 (permalink)
Member: 287772
Thanks Meter: 3
My pc is AMD athlon 64X2 Dual 4400+ no work.sign failed.
Old 01-18-2010, 07:08   #15 (permalink)
Member: 1087145
Thanks Meter: 162
work with INTEL
Torch For N70 Tested 100% working mani6 Nokia Multimedia 3 05-13-2010 13:23
Solution MXKEY ''Sign Apllication'' For AMD Prossesor! 100% working >> ..::AdnanRaj::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-19-2010 16:15
RAPIDSHARE (Free TuToRials for Free Users) 100% working Uwo_jj Off Topic Zone 3 11-19-2008 14:43
All Nokia for SAGEM 835 100% working!!! mihut Infineon C16X M51 & ARM7 M52 BASED 6 05-21-2000 15:42
Page generated in 0.31189 seconds with 9 queries
