02-03-2010, 16:35 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 305166 Status: Offline Thanks Meter: 12 | mx key problem with 3110c checked it with mxkey super dongle data was curropted repaired with mx key SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! but on makking pm auth it gives the following result Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 59.94.114.10 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request and on making super sd authorization it gives the following error Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! warning: SD authorized but verify failed ! pls help me |
02-03-2010, 18:35 | #2 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Street line baby
Member: 695310 Status: Offline Thanks Meter: 144 | with mxkey dongle Solution for: "SECURITY_TEST failed!" and "warning: SD authorized but verify failed!" Solution for: "SECURITY_TEST failed!" and "warning: SD authorized but verify failed!" If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 Manole |
MX-KEY Problem with Kaspersky Inernet Security[SOLVED] | omarsoos | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-08-2010 12:49 |
MX KEY Card with P-KEY | gsm_unlock2 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-03-2010 20:01 |
MX-KEY together with JAF P-KEY on one computer | janda | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-17-2010 16:27 |
Mx key problem with dct4 mobiles | javeed_mp | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 02-02-2010 13:09 |
mx-key problem with bb5 sl2 ?? | lmalali | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-23-2009 20:29 |
