07-08-2009, 08:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | MX-KEY RPL Server Working Fine Now! MX-KEY RPL Server is Working Fine now with ASIC 11 too (It was working for ASIC 2 always)! Here is log: Code: ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008DDED4:DA3BDA66 ASIC type: 11 UEM Imei: 35293002465287 Connecting to server ...OK, Login ... Hello C0800049, you have 800 credits left. RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35293002465287.RPL" ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-105 SW Version: V 5.23 10-03-08 RH-105 (c) NMP Imei plain: 35293002465287-9 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MG Br, Shadab Ahmad |
The Following 2 Users Say Thank You to [Shadab_M] For This Useful Post: |
07-09-2009, 16:49 | #3 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Karor lal eason Age: 43
Member: 151792 Status: Offline Thanks Meter: 15 | yes , working fine thanks mx key team , earlier i have NFF, its server is always down , when we need rpl , with nff server down and customer back it cell, since i purchased MX Key, no phone set go back by customer, when ever RPL needed server always work vry fine with mxkey, thankssssssssssssssss mx key team |
MX KEY RPL server not working | srinibas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 10-31-2009 16:11 |
server working fine now | aswadsaad988920 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 08-04-2009 17:09 |
Mx-key rpl dct4 rpl server working fine , test report | himanshu taldar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 06-20-2009 04:39 |
bb5 RPL is work fine now ? | .::NaNTeC::. | Gsmfather The Wholesale Unlocking Database | 6 | 11-13-2008 03:31 |
Hwk torrent server working fine now | mony_valley | HWK | 3 | 11-09-2008 14:48 |
