10-21-2011, 10:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 589 | MXBOX-KEY rev 1.4 and 1.3 at the same time If you want to delete it just give me your reasons before. COMMENTS ARE WELCOME GSMUNIVERS |
The Following 3 Users Say Thank You to Punto-Móvil For This Useful Post: |
10-21-2011, 10:29 | #2 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 589 | You can get this working having two MXBOX or one MXBOX and one MXKEY. You can also work with both version using one MXBOX and one rev at time: means if you have one MXBOX you can have installed both rev 1.4 and 1.3 but you can only run one at time if you execute rev1.3 , rev 1.4 will not detect smartcard because it is beeing used by rev1.3. If you want to know how just post your question here. Am testing it to see if system will stay stable or that will cause conflicts. Best Regards GSMUNIVERS |
The Following User Says Thank You to Punto-Móvil For This Useful Post: |
10-21-2011, 14:50 | #6 (permalink) | |
Member: 1147852 Status: Offline Thanks Meter: 589 | Quote: There is some difference between the case you are talking about (double instance)and mine for example you are using the same version MobileEx 3.4 rev2.0 for both cards while am using for one 3.5 rev 1.4 and for the other 3.5 rev1.3. My thread was not something extraordinary it was just an experience i made to use old rev 1.3 without modifying content of mobileEx folder by copying module folder to rev 1.4 as told here in some posts. the thing is ismple i have two partition in my laptop one for WIN 7 where i installed MobileEx 3.5 rev 1.4 and the other for WIN XP where i installed MobileEx 3.5 rev1.3 : Simply i made a shortcut from both sources(C:MobileEx/3.5/MobileEx.exe + D:MobileEx/3.5/MobileEx.exe) in each desktop and seems working perfect.Correct me if am forgetting something GSMUNIVERS | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
