09-07-2012, 12:36 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Where is your Buscheck Logs? Follow our Section Rules: http://forum.gsmhosting.com/vbb/f550...ection-984366/ or Thread can be Delete from next time. BR, ZUBER |
09-08-2012, 13:56 | #3 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: AT YOUR EYES
Member: 747386 Status: Offline Thanks Meter: 30 | Quote:
After flash nokia n 8 rm 596 log MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010016CF Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: nmwcdnsuc, ver: 6.85.10.27 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: RM-596_022.014_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 122.51 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 0DA0000B82D458408049CEEA5C23F6BAA4596C87 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0232 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: ED2F4CB FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1D8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35739804662158_CE RT.rpl). CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 2 min 22.421 s Processing PPM file: RM-596_022.014_13.01_MEA_A_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 47.30 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 55.422 s Processing PPM file: RM-596_022.014_C04.01_MEA_1_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 12.80 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.078 s Processing CNT file: RM596_APE_ONLY_ENO_11w15_v0.148.fpsx [BB5,XSR 1.6] size: 4.05 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 4.828 s Processing CNT file: RM-596_022.014_U07.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 95.62 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 262 MB CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF] Flash programming ... Programming completed in 1 min 56.516 s Total time for flashing process(boot+erase+write) was 5 min 40.453 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. | |
09-08-2012, 17:01 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | What is your Phone Product Code? Backup All Sections. Try Flash with Latest Firmware with same Product Code of Phone & Battery fully Charged. After Flash Go to Service > Quick Fix > Tick BB5 Downgrade Fix & Click Do Selected Job. If not solve, then post reply with all Logs. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
09-10-2012, 09:10 | #5 (permalink) | |
sir Zuber here is Product code: 0599396 | |
The Following User Says Thank You to geovicky For This Useful Post: |
09-10-2012, 10:15 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | You Flashed the Phone with Firmware Ver. 022.014 & the Latest Firmware of your Phone with Code is 025.007 Means you Downgrade the Phone by mistake. So Download Firmware Ver. 025.007 & Flash it, will solve yours, If not then, After Flash Go to Service > Quick Fix > Tick RAP3NAND Erase & BB5 Downgrade Fix > Click Do Selected Job. Must Solve yours, Post reply BR, ZUBER |
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post: |
09-11-2012, 09:03 | #8 (permalink) | |
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D Using device: USB ROM and HTI, FW ver: 00.50, SN: 010016CF Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: RM-596_025.007_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 122.51 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 0DA0000B82D458408049CEEA5C23F6BAA4596C87 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0232 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: ED2F4CB FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1D8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35739804662158_CE RT.rpl). CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 2 min 24.485 s Processing PPM file: RM-596_025.007_14.01_MEA_C_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 43.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 54.438 s Processing PPM file: RM-596_025.007_C06.01_MEA_3_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 12.30 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.078 s Processing CNT file: RM596_APE_ONLY_ENO_11w15_v0.148.fpsx [BB5,XSR 1.6] size: 4.05 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 5.297 s Processing CNT file: RM-596_025.007_U07.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 95.74 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 262 MB CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF] Flash programming ... Programming completed in 1 min 57.875 s Total time for flashing process(boot+erase+write) was 6 min 55.032 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. after flash new vr Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 0DA0000B82D458408049CEEA5C23F6BAA4596C87 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW NewProtocol is not supported for current interface (). Please select correct loader version from 'Config' menu sir zuber not solve my problem! | |
09-11-2012, 09:56 | #9 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Tick & Untick same as in Image, to work with Old Protocol. So go to Config Menu, follow Image & do the same. BR, ZUBER |
