04-03-2010, 13:45 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Salford
Member: 125401 Status: Offline Thanks Meter: 22 | MX Key wont unlock E73 Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Product: V ICPR71_09w22 29-05-09 RM-346 (c) Nokia ApeCoreSw: 300.21.012 Using cached productData[1C300108F6978B52A91B0BB767F2E25318F988F7] ... Calculating SIMLOCK using security server ... Completed in 33.484 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-346_358240031070360_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 358240031070360 Version: SIMLOCK SERVER Provider: Virgin, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F Trying to unlock Nokia E73 this is what comes up, any suggestions please? |
The Following User Says Thank You to mobileZONE For This Useful Post: |
04-03-2010, 18:08 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
First method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Repair SIMlock with MXKey 6 - Repair Superdongle with MXKey 7 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) The second method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Lock the by phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 6 - Repair SIMlock with MXKey 7 - Repair Superdongle with MXKey 8 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Third method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Erase Eeprom Section: Flashing-> Advance-> GetAddress, Disable Safe Erase. Enable Eeprom Part only, Click Erase. 3 - Locke the phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 4 - Repair SIMlock with MXKey 5 - Repair Superdongle with MXKey 6 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Originally posted by Y.P.Y, here is the original post link http://forum.gsmhosting.com/vbb/f550...lution-933709/ | |
The Following User Says Thank You to curvenger For This Useful Post: |
Is this Models Supported mx key for unlock? | caremobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 09-01-2009 04:47 |
MX-KEY supported unlock model list | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 06-12-2009 00:20 |
