12-05-2010, 11:25 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Pakistan Age: 38
Member: 756333 Status: Offline Thanks Meter: 152 | Nokia 5130c Hangs & White (ANSWERED) I flash with latest version 7.97 but the problem was same, Therefore i flash it again with downgrade version 7.95, Now phone is showing only Nokia logo, I've flashed again with 7.97 but problem is still nokia logo. Anyone have solution about this problem....? Thanks in Advance |
The Following User Says Thank You to Haider Ali For This Useful Post: |
12-05-2010, 12:05 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Bhumi Sang Mpu Aryya Wiraraja.
Member: 616567 Status: Offline Thanks Meter: 187 | 1. Flash phones with latest version 2. Backup cert with ufs then reset npc with mxkey if problem solved thats mean u need RPL to solved ur problem. 3. See in this thread maybe u can find the answer http://forum.gsmhosting.com/vbb/f299...27/index7.html OR hardware problem. check for flash chip. try check this master... |
The Following User Says Thank You to sharlen For This Useful Post: |
02-18-2011, 10:11 | #9 (permalink) |
No Life Poster Join Date: Jul 2007 Location: kolkata, india
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | 5130c only nokia logo no info found in hwk and I have done full flashing with 7.97 and reset npc and tryied without camera but problem not solved........ |
02-18-2011, 15:54 | #10 (permalink) |
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | I tryed nokia 5130c-2 (only nokia logo) with usb flashing but flashing terminated with error>>> Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2A5FEE1E CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 281001147EBA8D5671B9E4050A175B13E7C16A9F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Timeout, no usb device found. Flashing terminated with error(s) in 48.688 s |
02-18-2011, 21:54 | #11 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
The Following User Says Thank You to gbluez For This Useful Post: |
02-19-2011, 06:31 | #12 (permalink) |
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | Then how can i solve my problem with nokia 5130c-2 only nokia logo problem???? I have already flashed many times with fbus interface with latest version 7.97..... But problem is still same like only nokia logo after that set turns off and there is no info found on phone ... |
02-19-2011, 06:47 | #14 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Malaysia Age: 41
Member: 524147 Status: Offline Sonork: 100.1585889 Thanks Meter: 17 | Quote:
02-19-2011, 06:49 | #15 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | @haider ali try flash again using fbus, post the log now, don't lose it, hehehe... let's see what is wrong with the log. if using mxkey, at the end of process the phone is not responding, then try using hwk. may be your file is corrupted. but if u have flashed a lot of 5130 and they were normal before, then your file is okay... last option is try using ph****x c****k if u dont have other box for nokia. good luck br Last edited by specta; 02-19-2011 at 06:55. |
The Following User Says Thank You to specta For This Useful Post: |
