06-10-2009, 18:45 | #31 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | #Patch update - NK Added, Support for BB5 SIMLOCK SL3 Structure Fixed, WD2 CBUS Loader parse for correct BT flashing ------------------------------------ Download at: MXKEY - Official Mirror (rapidshare) http://rapidshare.com/users/P5JHS5 will also available in support area and download page. BR. |
The Following 46 Users Say Thank You to Alim Hape For This Useful Post: |
06-11-2009, 08:52 | #32 (permalink) |
Member: 43548 Status: Offline Thanks Meter: 2,192 | v3.2 revision 1.3, Public-Release #Patch update - MAIN Improved, privilege adjustment ; hopefully will solve not starts problem ?! ; So far tested with XP XP2(OEM), Vista Ultimate(NOT OEM), Vista Ultimate SP1 (OEM) - NK BB5 SIMLOCK SL3 Structure upload from RPL backup added. Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 BR. |
The Following 59 Users Say Thank You to Alim Hape For This Useful Post: |
06-23-2009, 18:31 | #33 (permalink) |
Member: 43548 Status: Offline Thanks Meter: 2,192 | v3.2 revision 2.1, Public-Release #Minor update - MAIN MTBOX boot fixed. Regular minor bugfix - NK Added, BB5 Secure Storage Validation on 'Scan' ; This will validate if SIMLOCK or SUPERDONGLE_KEY is corrupt or not. ; Usefull to determine WD timer or CS issue for BB5 phones. ; Phone with SUPERDONGLE_KEY corrupted, will affect in SX4 auth unsuccessfull or WD problem. ; Phone with SIMLOCK corrupted, will end with CS problem. Added, SIMLOCK2 phones detection (with PM308 protected/read only) ; SIMLOCK2 ('SL2' or 'SIMLOCK2' firmware) phones RPL backup will not work with this phone because of SUPERDONGLE_KEY cannot be restored. Added, ASIC_ID(RAP/OMAP) chip name information Added, flash size information Fixed, BB5 'get address' Fixed, BB5PLUS RPL backup read/write ; Restoring from RPL backup after EEPROM will also restore SUPERDONGLE_KEY so phone will not have WD timer issue. Forced to change phone mode to TEST_MODE when doing factory reset and Self Test. Added, DCT4 Manual Logger Fixed, UEM req timeout bug on previous release (rev2.0) Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 BR. |
The Following 24 Users Say Thank You to Alim Hape For This Useful Post: |
06-23-2009, 18:31 | #34 (permalink) |
The Following 36 Users Say Thank You to Alim Hape For This Useful Post: |
06-24-2009, 17:44 | #35 (permalink) |
Member: 43548 Status: Offline Thanks Meter: 2,192 | v3.2 revision 2.2, Public-Release #Patch update - NK Fixed, DCT4 Slow Flashing when using JAF interface. Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 full and partial setup uploaded. if you have already installed mobileEx_setup_v3.2_rev2.1.exe with limited internet bandwidth , you can update using the partial setup. BR. |
The Following 39 Users Say Thank You to Alim Hape For This Useful Post: |
07-01-2009, 20:07 | #36 (permalink) |
Member: 43548 Status: Offline Thanks Meter: 2,192 | v3.2 revision 3.0, Public-Release #Minor update - MAIN Fixed, Random crash on rev 2.2 Added, UI Style option ~ Goto Options|General Settings->GUI - NK Added, BB5 SW Downgrade in 'Quick Fix' ~ Use this option to patch PM308,1 Downgrade subblock without full flashing. ~ Usefull for phones which 'DEAD' after PM308 write or RPL backup write Added, Skip SX4 Auth Option on 'PM options'. ~ PM options is button with '>' in the PM tab Fixed, Multiple Content selection form vpl files. Fixed, DCT4 Manual Logger error if no service selected Phones image background color now changed to be match with variant Color on market selection Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 will also available in support area and download page. BR. |
The Following 68 Users Say Thank You to Alim Hape For This Useful Post: |
08-09-2009, 10:17 | #37 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | 09 august 2009 v3.2 revision 3.2, Public-Release Whats new: - Application core module loader routine changed - MAIN Minor bug fix - NK JAF BOX stability and compatibility improved (This will also fix problem with flash dead,random stops/hang when using JAF BOX) Added, Bus Check routine for 'Nokia USB ROM' (Useful for 'NORMAL' phones which could not connect to USB due to phone lock or something else) (After successful flash bus check phone will reboot to local mode, so you can do fbus operation such as: reset user code/factory reset) Added, Wlan settings in RF/BB tab Fixed, Keypad test start bug Fixed, Sometimes hang after flash erase Wlan settings also included when backing up ProgData Download link: http://rapidshare.com/files/26440431...3.2_rev3.2.exe PS: Just discovered Krombo identity and will be made public soon. |
The Following 66 Users Say Thank You to MANOLE For This Useful Post: |
08-13-2009, 17:42 | #38 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | v3.2 revision 4.0, Public-Release (Security Increased) 14 August 2009 v3.2 revision 4.0, Public-Release (Security Increased) Whats new: - MAIN Binary will no more run inside Virtual Machine Added, Intrusion detection against code framework manipulation Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 will be also available in support area and download page |
The Following 38 Users Say Thank You to MANOLE For This Useful Post: |
08-13-2009, 23:26 | #39 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | v3.2 revision 4.1, Public-Release 14 August 2009 v3.2 revision 4.1, Public-Release Whats new: - NK Fixed, PMM auth bug(application closed) on rev4.0 Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 will be also available in support area and download page |
The Following 77 Users Say Thank You to MANOLE For This Useful Post: |
09-11-2009, 20:08 | #40 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | v3.2 revision 5.0, Public-Release 11 September 2009 v3.2 revision 5.0, Public-Release - MAIN Added, Dongle License status Info in the Dongle Maintenance Gro***** Added, Update License Button ~ Used to activated custom license of the card which will be used for spesific feature/module To preserve bandwidth, Refill Button will be enabled if Counter < 50 % - NK Added, BB5 PA_SL2 NCK Calculator using security server ~ This will unlock most PA_SL2 phones with protected PM308:1 ~ This feature need License #1 to be activated(activation is FREE) Added, BB5 PA_SL2 Counter Reset Added, SAFE Erase routine while using 'Custom Flash Erase' on the 'Advance Page' ~ SAFE Erase will Protect PM Data from erase specially when doing 'Erase WHOLE flash'. ~ Usefull for recovering a DEAD phone without loosing SIMLOCK DATA Fixed, BB5 Secure Storage Validity for PA_SL3 phones Added, Automatic NPC backup while doing 'Skip SX4 Auth' and 'BB5 SW Downgrade Fix' Minor bug fixed. Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 also available in support area and download page BR, Manole |
The Following 87 Users Say Thank You to MANOLE For This Useful Post: |
10-02-2009, 14:17 | #41 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | MXKEY DCT4PLUS SP UNLOCK and Imei Changes for ASIC 0x3168 - v3.2 revision 5.2 02 October 2009 v3.2 revision 5.2, Public-Release MAIN - License #0 needs to be activated (activation is FREE) to load module. NK - Added, DCT4PLUS ASIC 0x3168 standalone 'on the fly' patch for SP UNLOCK and Imei Changes ~ This feature need License #1 to be activated (activation is FREE) - Added, Low Level format before CNT write - Fixed, Image Download 'in background' hang - BB5 Secure Storage Validity now support PA_SL3(unlocked) phones - Fixed, WD2(PPM) flashing using UFS - Many Minor bug fixed. Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 also available in support area and download page Public discussion for this update in this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=834728 BR, Manole GSM: +8613077861111 ICQ: 66-11-11 YM: manole4000 MSN: [email protected] SONORK: 100.88888 Web Page: http://www.manole.ro |
The Following 110 Users Say Thank You to MANOLE For This Useful Post: |
10-12-2009, 09:01 | #42 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | MXKEY v3.2 revision 5.3 11 October 2009 11/10 · v3.2 revision 5.3, Public-Release MAIN - Fixed, Windows Vista & Windows 7 compatibility. NK - Fixed, BB5 SIMLOCK_DATA/KEY PA_SL3 write - Fixed, BB5 RAPU-YAMA phones flashing - Fixed, DCT4 flashing bug(DEAD after flash/unlock) - Fixed, loading module sometimes failed - Improved, Module stability Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 also available in support area and download page Public discussion for this update in this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=840424 BUY ONLY FROM AUTHORIZED RESELLERS POSTED HERE: http://forum.gsmhosting.com/vbb/showthread.php?t=686432 BR, Manole GSM: +8613077861111 ICQ: 66-11-11 YM: manole4000 MSN: [email protected] SONORK: 100.88888 Web Page: http://www.manole.ro |
The Following 29 Users Say Thank You to MANOLE For This Useful Post: |
10-13-2009, 03:23 | #43 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | 13 October 2009 13/10 · v3.2 revision 5.4, Public-Release - MAIN Fixes for win vista and win 7, as posted in this thread. Rev 5.4 should load smoothly now. Perhaps add some new bugs, always open for report. Hunt them! NK - Added, BB5 'Restore SIMLOCK' from '*SIMLOCK.back' or '*.PM' or '*.RPL' FIRST AND UNIQUE IN THE WORLD ~ The button located at 'IMEI & Security'->'IMEI Rebuild'->'Restore SIMLOCK' - Fixed, DCT4 unknown flash bug(BUS check) - Fixed, DCT4 CS repair when phone could not go into LOCAL MODE - Refixed, DCT4 bootstrap for UFS interface - Fake Progressbar for BB5 flash erase reenabled. VCOM Recompiled PK83.bin for new api compability Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 also available in support area and download page Public discussion for this update in this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=840424 BUY ONLY FROM AUTHORIZED RESELLERS POSTED HERE: http://forum.gsmhosting.com/vbb/showthread.php?t=686432 Best Regards from mr. Manole GSM: +8613077861111 ICQ: 66-11-11 YM: manole4000 MSN: [email protected] SONORK: 100.88888 Web Page: http://www.manole.ro Last edited by MANOLE; 02-25-2010 at 01:17. Reason: added important info, we was again first in the world and unique solution |
The Following 96 Users Say Thank You to gbluez For This Useful Post: |
11-05-2009, 16:44 | #44 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | v3.2 revision 5.6, Public-Release v3.2 revision 5.6, Public-Release MAIN - Added, Application Signing system ~ This is new application security improvement ~ Application will check it signatures when needed, this will check unique card id, application version, and signature datetime validity ~ New created signature will be valid for next 6 month after signing ~ It means that after new update, you might need to 'Sign Application' if the current signature doesnt meet the requirement. ~ Before signing request, sw will set system datetime from ntp server if datetime is not correct. ~ Note: Make sure you have set you computer date,time. ~ The application signing system will not work on the computer with invalid date time ! - Removed, Ping on server check - Fixed, Windows Vista SP2 compability. NK - Added, BB5 RAPUYAMA v1.11 USB Flashing (specially for new Flash) FIRST AND UNIQUE IN THE WORLD BB5 RAPUYAMA v1.11 Phones list: 5630d (RM-431) 6720 Navigator (RM-491) 6700 Classic (RM-470) 6720 Classic(RM-424) 6730 Classic (RM-547) 6730 Classic (RM-566) 7020a (RM-497) E52 (RM-469) E55 (RM-482) E72 (RM-529) E72 (RM-530) - Added, Dynamic Camera Configuration upload - FIRST AND UNIQUE IN THE WORLD (This features located at 'Phone Test->Camera') - Added, TIKU CDMA Product Data (PREPAID_CS_TYPE) fix using server calculation (This features will consume credit, how much it will take will be displayed once you logged in using 'Dongle Id') (The Service tag is 'DCT4 IMEI+PRODUCT DATA') - Added, BB5 RAP3NAND Erase User Area in the 'Quick Fix' tab FIRST AND UNIQUE IN THE WORLD (Useful to fix BLANK/BLINK or doesnt switch on problem) - Added, BB5 PA_SL identification from PASUBTOC - Added, New CS type info for newer phone - Improved, FAST flash routine (SW will keep in flash mode when processing image file, means that it will skip boot and loader upload if config from each file is similar) - Improved, BB5 RPL write (SIMLOCK_DATA will be uploaded after NPC write, since new BB5 phone will only accept SIMLOCK_DATA if NPC is valid ! ) - Fixed, BB5 'Security block invalid' bug - Added, Detailed information for each 'Quick Fix' function. Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 also available in support area and download page Public discussion for this update in this thread: http://forum.gsmhosting.com/vbb/showthread.php?t=840424 BUY ONLY FROM AUTHORIZED RESELLERS POSTED HERE: http://forum.gsmhosting.com/vbb/showthread.php?t=686432 Best Regards from mr. Manole GSM: +8613077861111 ICQ: 66-11-11 YM: manole4000 MSN: [email protected] SONORK: 100.88888 Web Page: http://www.manole.ro br, Last edited by MANOLE; 02-25-2010 at 01:00. Reason: added RAPUYAMA v1.11 phones list |
The Following 96 Users Say Thank You to Andra For This Useful Post: |
11-24-2009, 02:01 | #45 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Hello all, there are available an update version MXKEY · v3.3 revision 1.0, Public-Release Major update MAIN Improved,Application Signing system - client time will be checked before signatures generation to avoid duplicate error request. - date-time issue bug on server side fixed. - no messages will be displayed if signatures invalid when working in FREE module (siemens). Added,Server status info on server check - ping check removed, so there will be no more firewall problem. Redesigned, Modules Manager page - This will make the possibility to update single module at future updates. Check for daily update re-enabled. - application will check update once a day and will be displayed in tooltips when new update found. NK - Added BB5 RAPIDO STN8815(N96) usb flashing(Dead Usb also possible) - Fixed DCT4PLUS ASIC 0x3168 patch unlock and imei changes (2630 v52.70,2680 v06,80) - Fixed BB5 Flashing (partitioning bug) - Fixed Fast flashing bug when using JAF box. - Added PM308 1 backup on 'BB5 SW downgrade fix' Other modules recompiled for major api changes. ------------------------------------ Please 'Sign Application' first,make sure you have correct date,time setting on your computer. Every card have 5 chances to request digital signature from server. DOWNLOAD DIRECT LINK HERE Also Available Download from: MXKEY- Official mirror http://rapidshare.com/users/P5JHS5 Buy only from MXKEY authorized resellers: http://forum.gsmhosting.com/vbb/showthread.php?t=686432 MXKWY v3.3 revision 1.0 public discussion thread: http://forum.gsmhosting.com/vbb/showthread.php?t=866543 ps: as you can see, "Redesigned, Modules Manager page" just keep watching what will be appear in short time PS2: Added a special message Save Energy to Stop Global Warming and to Save our EARTH !!! Fight climate change by supporting RAINFORESTS project: http://www.rainforestsos.org Best Regards, Mxkey Last edited by MANOLE; 11-24-2009 at 19:35. |
The Following 72 Users Say Thank You to gbluez For This Useful Post: |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! | andrew bennett | Main Sales Section | 1 | 07-27-1999 21:31 |
