Old 03-18-2014, 06:30   #1 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Nokia C5-00 Only restart
I flash the phone with Latest version But Same problem
Here is USB flash LOG
MXKEY [FT SCR2000 0], SN: C0815FC5
Using device: USB ROM
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Processing MCU file: rm645_071.005_prd.core.fpsx
[BB5,XSR 1.6] size: 96.64 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 2B50010590BF0D49F8C525FCC6933B5A6CC4D1F9
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD45F0
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: F8A95B4
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35934503402894_CE RT.rpl).
CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 170.06 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 16.796 s
Processing PPM file: rm645_071.005_14.01_APAC2_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 30.61 MB
Erase size: 51 MB
CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 5.250 s
Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 8.01 KB
Erase size: 14 MB
CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.031 s
Processing CNT file: RM645_ENO_10wk48v0.001.fpsx
[BB5,XSR 1.6] size: 2.25 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
CMT SOS*ENO block sent
Programming completed in 0.437 s
Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx
[BB5,XSR 1.6] size: 1.32 MB
Erase size: 72 MB
CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF]
Programming completed in 0.656 s
Total time for flashing process(boot+erase+write) was 41.391 s
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Old 03-18-2014, 07:00   #2 (permalink)
Member: 1895099
Sonork: 100.1647265
Thanks Meter: 148
flash with same product code files if same check hardware
Old 03-18-2014, 07:03   #3 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
I already flash the phone same product code but no chsnges
Old 03-18-2014, 15:46   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Backup PM & RPL,
Then Erase Phone & Flash with Latest Version will solve it.
BR,
ZUBER
Page generated in 0.15688 seconds with 8 queries
