MXBOX THUNDER Successfully flashed |
Version from phone: 07.97 Version from file: 07.97 MXKEY [FT SCR2000 0], SN: C087FEA0 Using device: HTI, FW ver: 80.12, SN: 020040B2 Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) RPL backup already exist (C:\mobileEx\3.5\data\backup\BB5_35342104739857_BA CK.rpl). CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2330020684C94950C27709FD195DA540FE6CF958 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 1 min 14.391 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 30.407 s Processing PPM file: rm495__07.97.ppm_t [BB5,BB5 ALGORITHM] size: 7.43 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 31.594 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 36.953 s Processing CNT file: rm495__07.97.image_t_au_red [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] CMT FLASH,NOR area [02160000-03FBFFFF] erased in 1 min 8.953 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 50.875 s Total time for flashing process(boot+erase+write) was 5 min 58.328 s Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35342104739857-4 Product code: 0571593 Battery voltage: 4920 mV, current: 89 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353421047398574 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
