02-28-2012, 11:36 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. click synchronize files & then bucheck, if not solve then check your HTI box for hardware malfunctioning by using latest HTI software updater. |
02-28-2012, 11:46 | #6 (permalink) | |
Freak Poster Join Date: Feb 2012
Member: 1725935 Status: Offline Thanks Meter: 21 | Quote:
Definitions file is identical and up to date, no need an update. » Begin transaction ... Initializing HTI ... HTI initialized. Boot version: 00.07 Serial: ???????? Receive firmware from server ... SERVER->MXKEY - BLADE Z at upd, agent version 1.2 revision 0.2 Firmware version on server: 00.50 changes: added: boot mode switch function improved: serial and flash bus communication routine added: dct4 product data calc algorithm added: broadcom sec.repair algorithm minor bug fixed. Received buff checksum verified OK. Updating HTI firmware, please WAIT ... HTI firmware update OK. » End transaction (status: 0, Successfull) Waiting HTI in application mode ...Done. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: ???????? Using device: HTI, FW ver: 00.50, SN: ???????? Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) ASIC ID: 0x2293 [UPPCosto ver: 2.0] Error sending bootloader ! | |
02-28-2012, 12:26 | #9 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. you are checking nxp on old version from support site, see this is latest so download from here, install & check for nxp malfunctioning, because on working HTI box your phone error will not show. see this: MxBox HTI Firmware Updater v3.6 rev1.7 Changes: - OTP ID correct reading fixed - Ver 1.4 and 1.5 become obsolete Previous version changes: - Working now also in Windows XP - New option button added: "Check NXP Bug" with automatic create discount Voucher for use to order online MXBOX GREEN at 15 USD with free delivery BUY MXBOX GREEN at 15 USD WITH Discount VOUCHER and FREE DELIVERY Screen shots: If your HTI is OK you will get this (Windows XP): If your HTI have IC with NXP bug will get this (Windows XP): Latest HTI firmware version is 00.50 please Update HTI by using "Update HTI" button ! 60 links for download MxBox_HTI_FirmwareUpdater_v3.6_rev1.7: MxBox_HTI_FirmwareUpdater_v3.6_rev1.7_3.zip MxBox_HTI_FirmwareUpdater_v3.6_rev1.7_2.zip MxBox_HTI_FirmwareUpdater_v3.6_rev1.7_1.zip MxBox_HTI_FirmwareUpdater_v3.6_rev1.7_0.zip MxBox_HTI_FirmwareUpdater_v3.6_rev1.7.zip |
02-28-2012, 12:27 | #10 (permalink) |
02-28-2012, 12:52 | #11 (permalink) | |
1202 1200 1202 scan ok bus check error Last edited by gokhaniletisim; 06-25-2012 at 16:46. | |
02-28-2012, 14:15 | #13 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | @ gokhaniletisim hey hey congratulation bro. u got same error as mine. noone can answer you exact in this problem.. i know u get problem in DCT4 models like 1110,1200,1208,1650,1202 first time when u scan the phone it shows local mode then full logs can be seen.. but when u buscheck it will just stops on ERROR SENDING BOOTLOADER & then MOBILEX goes hang!!!!!!! dont be sad, your box is not faulty. u can check your box in someone's pc who doesnot have such problem in his BOX. so waiting for official solution. regards.. |
02-28-2012, 14:22 | #14 (permalink) | |
How do I resolve this error? You etttinmi repair this error? | |
The Following User Says Thank You to gokhaniletisim For This Useful Post: |
02-28-2012, 15:48 | #15 (permalink) | |
mr zuberchowdhry I added the picture that you wanted to Last edited by gokhaniletisim; 06-25-2012 at 16:46. | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
