Old 05-20-2013, 08:36   #1 (permalink)
Registered User
Member: 1597393
Sonork: 6692766
Thanks Meter: 4
Nokia c2-01 rm-721 contact service.simlocks r ok
HERE IS LOG
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0108
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Processing MCU file: rm721__11.40.mcusw
[BB5,XSR 1.6] size: 28.58 MB
Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600000001
020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 2D20010EC299604047DA9A2CE03134E845CB0907
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH:
7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 73747B3
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35931804356070_CE RT.rpl).
CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 37.69 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0025FFFF]
CMT FLASH,MuxOneNAND area [003E0000-005DFFFF]
CMT FLASH,MuxOneNAND area [005E0000-010DFFFF]
CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF]
CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF]
CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF]
CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 8443ECD5 [] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 56.219 s
Processing PPM file: rm721__11.40.ppm_d
[BB5,XSR 1.6] size: 7.08 MB
Erase size: 8.87 MB
CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF]
Programming completed in 13.718 s
Processing CNT file: 10C9EC5D_rm721__11.40_008.image_d_vipmobile_rs_9g7 h3
[BB5,XSR 1.6] size: 20.09 MB
Erase size: 75.06 MB
CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF]
Programming completed in 39.797 s
Total time for flashing process(boot+erase+write) was 2 min 3.485 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-01 USB Phonet, PORT_ID: 359318043560708
Verifying communication to device OK.
Phone type: RM-721 (Nokia C2-01)
SW version: V 11.40 24-10-12 RM-721 (c) Nokia
Imei plain: 35931804356070-8
Product code: 059D644
Battery voltage: 3984 mV, current: 87 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00IIIIRR0301035602, ver: 001.002
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359318043560708
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Market items is empty, please select the correct products path !
Old 05-20-2013, 08:55   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Start self test, see any error logs there. paste here the logs
Old 05-20-2013, 09:26   #3 (permalink)
Registered User
Member: 1597393
Sonork: 6692766
Thanks Meter: 4
Phone Type: RM-721
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y !failed !
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N passed
43 LCD N passed
21 LPRF_IF N passed
44 LPRF_AUDIO_LINES N passed
2 CURRENT_CONS N passed
42 RADIO Y passed
23 KELVIN_BATVOLTAGE N passed
19 KELVIN_VIBRA N passed
26 KELVIN_CAPACITOR N passed
29 KELVIN_MISC N passed
28 KELVIN_MIC N !no signal
31 KELVIN_CHARGING N passed
27 KELVIN_AUDIO N passed
116 KELVIN_XEAR N passed
105 INTERNAL_ANTENNA N passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
71 BT_WAKEUP N passed
96 HOOKINT N passed
88 TAHVOINT Y passed
101 BTEMP N passed
8 MBUS_RX_TX_LOOP Y passed
90 PWR_KEY N passed
128 CDSP_SLEEPCLOCK_FREQ N passed
86 CDSP_RF_BB_IF N !no signal
83 CDSP_RF_SUPPLY N !no signal
85 CDSP_TX_IQ N !no signal
74 CDSP_TXC_DATA N !no signal
79 CDSP_RX_PLL_PHASE_LOCK N !no signal
80 CDSP_TX_PLL_PHASE_LOCK N !no signal
75 CDSP_WCDMA_TX_POWER N !no signal
81 CDSP_RX_IQ_LOOP_BACK N !no signal
77 CDSP_GSM_TX_POWER N !no signal
Old 05-20-2013, 09:43   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
SIM_CLK_LOOP Y !failed >> power chip damaged. it's hardware problem.
Old 05-20-2013, 09:50   #5 (permalink)
Registered User
Member: 1597393
Sonork: 6692766
Thanks Meter: 4
bundle of thanks sir
Page generated in 0.19164 seconds with 8 queries
