05-11-2011, 06:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | mxkey ded 2220s in flashing #! erase data and writing problem and this time 2220s total ded no flash i try to all other tool but fail hear is log MXKEY Serial: [FT SCR2000 0] - C0818B55 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16818(08-05-2011), Library ver: 1.0.0.9921(04-05-2011) Processing MCU file: rm590__10.25.mcusw [DCT4,DCT4 ALGORITHM] size: 11.32 MB Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0006F543:3B8ADA60 Area [01000000-0101FFFF] erased in 1.218 s Area [01020000-01CFFFFF] erased in 2 min 2.469 s Flash programming ... Error while programming [14] at 0x01000000, Result: 0072 flashing terminated ! Task failed at (08000025)!!! Last RX buffer: 00 72 i think mxkey is ded tool 100% working set is ded with mxkey |
05-11-2011, 06:52 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | again do some tricks bro. tik safe flash tik fast flash untik safe flash untik fast flash tik safe flash untik fast flash tik fast flash untik safe flash also try skip erase. |
05-11-2011, 08:28 | #5 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | MXKEY Serial: [FT SCR2000 0] - Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16818(08-05-2011), Library ver: 1.0.0.9921(04-05-2011) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0006F543:3B8ADA6A ASIC type: 11 UEM Imei: 35485304715426 Flash Imei: 35485304715426 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35485304715426_BA CK.rpl" Processing CNT file: rm590__10.25.image_ae_au_hpink [DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.63 MB Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0006F543:C5A4DA6A Erase skipped. Converting UCP blocks to 128 K. Flash programming ... Error while programming [14] at 0x02180000, Result: 0072 flashing terminated ! Task failed at (08000025)!!! Last RX buffer: 00 72 not luck other cable other box |
10-06-2011, 17:51 | #8 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Makum, Assam, India
Member: 1540165 Status: Offline Sonork: 100.1606502 Thanks Meter: 29 | Quote:
There is no such bug in MXKEY Try with latest firmware. | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
