03-01-2012, 13:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1725935 Status: Offline Thanks Meter: 21 | mxkey djt4 (1110 1200 1202 1650) error sending bootloader There is no problem at all bb5 mode. djt4 have only some of the model device. I changed bcp69 I checked the chip HTI. I tried another pc. Unfortunately, many users like me, this error is encountered. what mr Manole when will it? MXKEY SCAN , BUSCHECK Phone type: RH-112 SW version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 356??????????-? Product code: 0562273 Cellular system: GSM ASIC ID: 0x2293, type: 11 Ppm Id: AD Language Pack: English,French,German,Turkish Master code: 2705240163 Imei net: 356?????????? Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: ????????? Using device: HTI, FW ver: 00.50, SN: ????????? Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) ASIC ID: 0x2293 [UPPCosto ver: 2.0] Error sending bootloader ! __No problem with the same phone in the same cable ufs__ UFS İNFO CHECK MCU SW : V 03.10 21-01-09 RH-112 (c) NMP PPM SW : V 03.10 21-01-09 RH-112 (c) NMP AD Prd.Code: 0562273 Bpr.Code: 0558505 Prod.Sn : IJP481092 HW Vers : 2004 UEM : 1328 UPP : 8851 [2293] RFIC Ver: 0700 DSP Vers: ICPR81_08w31_UPP LCD Type: WIN:SERI:90 NT7542 IMEI : 356???-??-??????-? SL Conf : 001-01-00000000000 SL Prof : 000000000003000-B SL Var : 00003569980162905100 SL Aux : 000B0000 HW Sig : CEC62347137EE6A5 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment 1st Boot: Ok, DCT4, UPP: 2293 [Rh-112] [2.2.0.3] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2606,Sam K8S3215ETF Algorithm: u3_amd.fia, Ver: 4.79.0 Rebooting Mobile Last edited by gokhaniletisim; 06-25-2012 at 16:46. |
03-02-2012, 11:28 | #3 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | just tested on 1202 an hour ago, error sending bootloader too. usually i flash dct4 with hwk, i saw error reported and just tested on hti when i have 1202 to flash just now. fyi, its okay n done by hwk as usual. fix this please sir br |
03-02-2012, 11:33 | #4 (permalink) | |
Member: 1725935 Status: Offline Thanks Meter: 21 | Quote:
you are so ridiculous you can talk to other things instead of talking to answer my question | |
03-02-2012, 11:42 | #5 (permalink) | |
03-02-2012, 12:49 | #6 (permalink) | |
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
and i never intended to answer your question, i just said i had the same issue. or my english is too bad to understand bro? br | |
03-02-2012, 13:57 | #9 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | Quote:
i think u have understood somethings..so rather to cry for few bugs, u need to complement yourself with other tools.& one thing if a single tool can do all things of a brand then what will other developers do? | |
The Following User Says Thank You to rabirabi For This Useful Post: |
03-02-2012, 15:14 | #10 (permalink) | |
I did not ask such a question. I do not want to listen to fairy tales Reply to want to write my question | |
03-02-2012, 15:48 | #11 (permalink) | |
See the pictures? ufs and Jaff to repair this error? Last edited by gokhaniletisim; 06-25-2012 at 16:46. | |
03-02-2012, 18:35 | #12 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | so what use cyclone,best,fenix for complement if u have.. if not better u buy a one as my advice.. or u just wait..........when mxteam releases next hti fw. professional men dont talk like this.if software have bug, they just inform to managers.if manager dont support then they should take their own way. |
03-02-2012, 21:07 | #13 (permalink) | |||||
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
