e7-00 usb error Using device: Nokia E7-00 USB Phonet Error opening ! Last error: The handle is invalid (code: 6) Nokia E7-00 USB Phonet disconnected. and lifetimer reset error wbr |
mr.Manole this is not fair update without ufs mxkey startup with ufs remind it sir:eek: |
PC cannot read scard after update! There's no driver for scard in driver folder.?????? |
1680C (RM-394) flash successfully in new version... http://i49.photobucket.com/albums/f261/nf6_tony/31.jpg |
same problem here please solve this...........:confused: |
Good Day Sir MANOLE! I have a probbem regarding MXBOX 3.5 rev 1.1 everytime i flash an N70 unit it only shows like this... heres the logs: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C08215F9 Using device: HTI BOX, FW ver: 00.17 Driver: USBUHCI:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.11291(14-06-2011) Processing MCU file: RM84_50737301.C0 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100701, 17100702 APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 139A2E8B524F6C0C1E090622C718CC9D4C1A95B0 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1350020C09CD5851001A0978091B488D1FCDDD23 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 Sir MANOLE I also updated my mxbox 3.5 rev 1.1 with your minor update. Sir kindly fix this error on N70.I have big trust on your software. please fix this bug on mxbox...i am using fbus flashing sir. THANK YOU VERY MUCH SIR MANOLE AND BEST WISHES TO MXBOX AND YOUR TEAM! |
http://www.yukleresim.com/images/021...6127661469.jpg Hello sir, what's this problem plzz answer here i am installing mxkey new setup after install show this massage. Br. .:::Aloktheultimate:::. |
good update br manole |
Now, i am use to mx-box. |
thanks mxkey..its tested with out any problem...... |
Ok, I got it...after thousands of retries.... I read one of those thumbnails above and deleted the XML file. Reinsert and w*****...it works.... |
UPDATE: Forgot something, I manually copied all files under C:\mobileEx\3.5\data\drivers\hti into system32 folder. INF files into c:\windows\inf folder.... |
HTI BOXES NOT UPDATE GETTING THIS ERROR » Begin transaction ... Initializing HTI ... » End transaction (status: 3) |
