03-11-2010, 14:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: THE END Age: 40
Member: 195225 Status: Offline Thanks Meter: 94 | 1661 imei problem ( i flash yhe fone v3.00 ver 3.10) Phone Type: RH-121 SW Version: V 03.10 02-11-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: UB Language Pack: - not available. Imei plain is invalid !!! Failed to read SP data |
03-11-2010, 14:32 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
03-11-2010, 14:51 | #3 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | same problem Connecting to server ...OK, Login ... Hello xxxx, you have 2000 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\01188500219186.RP L" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-121 SW Version: V 03.10 02-11-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: UB Language Pack: - not available. Imei plain is invalid !!! Failed to read SP data |
04-03-2010, 02:41 | #9 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1150048 Status: Offline Sonork: [email protected] Thanks Meter: 2 | 1661 b2 RH-121 imei plan is invalid plz help . |
04-03-2010, 02:43 | #10 (permalink) |
Member: 1150048 Status: Offline Sonork: [email protected] Thanks Meter: 2 | 1661-2 rh-122 unlock sulotion plz help any body |
1661 imei chang?????? | mobiletuch | Nokia Hardware & Hardware Repair | 1 | 06-09-2010 09:32 |
1661 imei chang possible?? jaf | mobiletuch | Nokia Hardware & Hardware Repair | 19 | 06-09-2010 09:29 |
1661 imei ??????????? | sami4323 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-12-2010 20:42 |
122 1661 imei & simloks | kamal dhiman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-13-2010 11:14 |
1661 imei | software.usm | Universalbox | 6 | 10-29-2009 08:39 |
