mxkey server down.......WHY???????? i wants to write rpl and i m trying to connect with mxkey server.......it says........Connecting to server ...Timeout on read (select()) after 30 seconds......... |
check again server is working well |
i dont think sir............................. ASIC ID: 0x2201 [UPP_v2.2x] u_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD 29BDS320] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001A6569:2984DA60 ASIC type: 2 UEM Imei: 35275501179476 Connecting to server ...Connection timed out |
Server MX-Key sugarcane but how the parents asked that the fight |
server is working well & WHAT IS YOU PROBLEM CAN YOU TEL ABOUT THE MX - KEY RPL FOR BB5 SERVER IS NOT WORKING WELL THANKS |
wait still server down...will restore soon...sx4 and rpl gogger not working....mx-key server will back soon |
Connecting to server ...TCP/IP Socket error: Timeout on read (select()) after 30 seconds JAF FLASHER INTERFACE disconnected. TCP/IP Socket error: Timeout on read (select()) after 30 seconds TCP/IP Socket error: Timeout on read (select()) after 30 seconds TCP/IP Socket error: Timeout on read (select()) after 30 seconds TCP/IP Socket error: Timeout on read (select()) after 30 seconds TCP/IP Socket error: Timeout on read (select()) after 30 seconds and this |
Using device: UFS2 SarasSoft Interface: Tornado (www.ufsxsupport.com) » UFxBoot V2.2 (c) SarasSoft 2003. » UFS_USB V2.8 (c) SarasSoft 2007. UFS2 SarasSoft ready. TCP/IP Socket error: Timeout on read (select()) after 30 seconds |
plz mxkey server get well soon.........if today server will not work well....i will be lost 150/rs. and a customer...................when it will ok....... |
Man dont cry for Rs.150 , Just think how this team feel today when some one trying to destroyed there hard work with cracking MXkey, We must pray to protect this kind of low cost GOOD repair tool , REGARDS |
YES NOW server down. FOR THE TIME GSM3_L@B |
