Old 02-06-2010, 09:48   #16 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35602903529180-5
Product Code: 0544343
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2008-11-12T13:00:19Z
SW Version: 07.21
Variant Version: 012
ProductProfile: RM237_0544343_07.21_012.spr
Simlock: 0544343_simlock.bin
Imei net: 356029035291805
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFF
horry 3110c done sucsfully
thanx manole
The Following 4 Users Say Thank You to klmamn For This Useful Post:
Old 02-06-2010, 09:48   #17 (permalink)
yasminato's Avatar
Member: 558412
Thanks Meter: 117
Originally Posted by MANOLE View Post
We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...)
Now all SD repair should work well.
Here is general repair procedure.
It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....).
It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones.
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here:
http://rapidshare.com/files/34542441...e_by_MxKey.zip
http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip
http://www.4shared.com/file/21610198...thout_NPC.html
http://www.megaupload.com/?d=2MSDVYSY
Please report your results in this thread.
Manole
wowwwwwwwwwwwwww prb solved here is last log
Imei plain: 35930902268102-9
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 359309022681029
Counter: 0/3, 0/10
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-06-2010, 09:49   #18 (permalink)
sagar_lse's Avatar
Member: 777523
Sonork: 100.1584558
Thanks Meter: 335
MANOLE SIR PLEASE POST SALUTION FOR SECURITY_TEST failed!
The Following User Says Thank You to sagar_lse For This Useful Post:
Old 02-06-2010, 09:49   #19 (permalink)
mobile house dinajpur's Avatar
Member: 724680
Sonork: 100.1595118,1603297
Thanks Meter: 928
not work for me try many but same
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
ERROR: Missing SD BLOCK or PM corrupted !
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 119.30.36.56
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-06-2010, 09:50   #20 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
Need to update over box or its work fine in old ver .......
Old 02-06-2010, 09:51   #21 (permalink)
i-Fixed's Avatar
Member: 1190236
Sonork: 100.1589642
Thanks Meter: 233
Nothing 3120c included? Please upload sir manole. Thank's.
Old 02-06-2010, 09:53   #22 (permalink)
misbah123's Avatar
Member: 165120
Thanks Meter: 16
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 07.23 17-07-09 RM-411 (c) Nokia
Imei plain: 35366201207696-4
Product Code: 0563611
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK_TEST passed
TimeStamp: 2009-07-22T07:56:36Z
SW Version: 07.23
Variant Version: 008
ProductProfile: RM411_0563611_07.23_008.spr
Simlock: 0563611_simlock.bin
Imei net: 353662012076964
Counter: 0/3, 0/10
really thankx 5220 ok now
Old 02-06-2010, 09:53   #23 (permalink)
daveiant's Avatar
Member: 804247
Sonork: 1593659
Thanks Meter: 310
Nice work Mr. Manole....we love you.!!! i got 1......Problem solved........
Before
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 15E00108E89E7C56B3DD967EBB9929A1FB388882
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 3593100XXXXXX
Original Product code: 0566832
Bluetooth ID: 002404EF7133
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 3593100XXXXXXX
Product Code: 0566806
Language Pack:
- not available.
SIMLOCK_TEST passed
TimeStamp: 2009-04-21T08:40:14Z
SW Version: 06.51
Variant Version: 011
ProductProfile: RM436_0566806_06.51_011.spr
Simlock: 0566806_simlock.bin
Imei net: 3593100XXXXXX
Counter: 0/3, 0/10
write PM
AFTER
Cheers!!
Old 02-06-2010, 09:55   #24 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
Thanks Meter: 2,390
Using device: J.A.F, FW ver: 01.B0
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0700010826B45850504F24EE1BF4496252DA3201
ASIC MODE ID: 00
Original Imei: 35574302617961
Original Product code: 0566913
Bluetooth ID: 0022FDEACB75
SW Version: V 06.51 23-03-09 RM-436 (c) Nokia
Imei plain: 35574302617961-0
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 06.51
Imei net: 355743026179610
Counter: 0/3, 0/10
thanks mxteam problem solved
Old 02-06-2010, 09:57   #25 (permalink)
Member: 118601
Thanks Meter: 200
Manole
should i copy those file here : C:\mobileEx\3.3\data\backup\RPL
Old 02-06-2010, 09:58   #26 (permalink)
Member: 1040522
Thanks Meter: 38
another download link: here
Old 02-06-2010, 09:58   #27 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
The Following 2 Users Say Thank You to razib143 For This Useful Post:
Old 02-06-2010, 09:58   #28 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
thankx thankx thankx Mr.Manole And MX Key Team
Old 02-06-2010, 09:59   #29 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_355718025711779_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 355718025711779
Counter: 0/3, 0/10
No SX4 Card found.
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 83.110.142.43
Old 02-06-2010, 09:59   #30 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
Solution is simple
Do Super_SD_Auth and Write Good Pm...
The Following User Says Thank You to .::Skylinks::. For This Useful Post:
1000% All Sl1 & Sl2 Solved "SECURITY_TEST failed!" after SD repair jonysant MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 07-18-2010 15:58
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" MANOLE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 164 05-05-2010 12:17
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" MANOLE Service Products News & Updates 0 02-07-2010 23:17
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 10:30
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair MANOLE Service Products News & Updates 0 02-06-2010 10:10
Page generated in 0.33608 seconds with 10 queries
