Old 03-18-2013, 12:03   #1 (permalink)
Member: 1726229
Thanks Meter: 223
Nokia 206 Fully Dead Successfully flashed MXkey
Model Nokia 206 Rm 872
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.53
EBL version: Quantum_Bootloader_10.53_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: xxxxxxxxxxxxxxx
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_xxxxxxxxxxxxxxx _back.RPL)
Processing file: rm872__03.59.mcusw
Downloading item CODE:rm872__03.59.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.344 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.343 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.406 s
Erasing area 0x40280000-0x41A7FFFE ...OK
Programming completed in 29.234 s
Checksum verified (0xB02A)
Processing file: rm872__03.59.ppm_mh2
Downloading item CUSTackage_mh2.ppm_ebl_psi.fls, num block: 1, size: 5.23 MB
Erasing area 0x41A80000-0x41FB92C6 ...OK
Programming completed in 6.594 s
Checksum verified (0xAB61)
Processing file: rm872__03.59.image_mh2_059Q316_059R9M3_232_01
Downloading item CUST:rm872__03.59.image_mh2_059Q316_0 , num block: 1, size: 16.50 MB
Erasing area 0x42100000-0x43E1FFFE ...OK
Programming completed in 20.187 s
Checksum verified (0xCF52)
Total time for flashing process(boot+erase+write) was 9 min 41.312 s
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 1749493
Verifying communication to device OK.
Phone type: RM-872 (206)
SW version: V 03.59 24-12-12 RM-872 (c) Nokia
Imei plain: xxxxxxxxxxxxxx-5
Product code: 059Q4L5
Language Pack:
- not available.
Imei net: 35xxxxxxxxxxxxxx0
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000004000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 0.125 s
The Following 2 Users Say Thank You to Ahsaan* For This Useful Post:
Old 10-20-2013, 11:36   #2 (permalink)
Member: 1122732
how to change lcd .by sacecful
Old 10-22-2013, 11:56   #3 (permalink)
Member: 1707676
thanks for the instruction!
Old 12-11-2013, 13:37   #4 (permalink)
Member: 2051567
nokia 206 flashing problem
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Sending EBL ...OK
ERROR: EBL not running. try to disable "Use embedded SBL from MCU" in config
flashing terminated !
Old 12-11-2013, 14:31   #5 (permalink)
Member: 1966461
Thanks Meter: 8
tnx.....problem solve...
Old 07-06-2014, 21:55   #6 (permalink)
Member: 1365327
please someone help me
How do i reset user code or factory setting of any phone like nokia 205 without flashing it using usb cable, with mxbox. The code is unknown.
Old 02-16-2016, 08:28   #7 (permalink)
Member: 2525883
nokia 206 not going on
Old 06-12-2018, 23:59   #8 (permalink)
Member: 1509896
Thanks Meter: 2
for me , solved by flashing the phone with PHONIX tool
The Following User Says Thank You to xAghilx For This Useful Post:
Page generated in 0.15734 seconds with 8 queries
