05-18-2012, 07:15 | #1 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1720169 Status: Offline Thanks Meter: 77 | mxkey sl3bf attack problem [solved] here you can see the that sl3bf->IMEI: 35430504977982 sl3bf->HASH: E33901758823D58EEAA67BEDCDF850EAFBCCB60D sl3bf->SALT: 03000800 sl3bf->start child targeting 11 digit password. sl3bf->CMDLINE: --gpu-watchdog=0 -m 110 -n 160 --pw-min=11 --pw-max=11 --hex-charset --hex-salt --outfile-format=4 --outfile=__out.txt -1 00010203040506070809 E33901758823D58EEAA67BEDCDF850EAFBCCB60D:030008000 03543050497798200 ?1?1?1?1?1?1?1?1?1?1?1 sl3bf->end child (elapsed 36614 ms) that 3080 is the salt of which we cannot get any % status represented by GUI as the process of oclhastcat-lite.exe is not been opened successfully by sl3bf.exe this could lead to the following: that if the master code with salt 3080 will not be recognized by the sl3bf.exe and hence may be your right code will be lost and even after your run this 100 % you wont get a code... 2 nd case this is running fine as we can get the status successfully and if the code is hit than i will be known to the sl3bf.exe and hence it will show "success". so now how to get it so go to the location C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169} and you will find the .log files like sl3bf.log now open it and ctrl+f then find elapsed 1 this will all the process that will have been terminated in 10 sec as my 100% for one salt time is 35.5-36.5 sec hence if salt hits then it would be in 1-29 sec so when we search for elapsed 1 or elapsed 2 you can see here so the solution is regularly check for log file by this search "elapsed (10-80 % time ) of the your one salt time " [COLOR=*****Brown]like in my photos my normal salt time is about 3652ms so if hit is there then the process would have been terminated in 1000-2900 ms so i search for "elapsed 1 " or "elapsed 2". so let request Mr. manole to make a fix..... [/COLOR] |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
