02-18-2013, 08:50 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. HTI Box is Standalone, needs no SX4 Server, Better post your problem with possible Logs or Screen Shot for assistance. BR, ZUBER |
07-02-2013, 02:50 | #3 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1914602 Status: Offline Thanks Meter: 1 | ST_Security failed when after SD repair and Super SD auth Hey MxKey guys, I am getting the ST_Security failed, and SD is OK after doing standalone Super SD auth for hash "3AB5DB70B45D23F1ADEEBB5734160706" . SX4 server is offline. 2 days same procedure works fine but then SX4 autherized using online server. Is there is some bug in standalone SX4 for bb5. Is the above mentioned hash is supported in stanalone version ? |
07-02-2013, 07:28 | #5 (permalink) | ||
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
If you want to be an Expert & solve with quick solution for Security Test Failed, Just follow this Thread: http://forum.gsmhosting.com/vbb/f550...ailed-1471251/ Mean while, try this Method: Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select your Phone's .PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result, post reply if not solve. BR, ZUBER | ||
07-03-2013, 17:09 | #8 (permalink) |
Member: 1914602 Status: Offline Thanks Meter: 1 | Thanks Juber and Goodman. Problem solved What i did, 1. full PM write leaving 1,309 2. RPL write in dead mode and then load the PM file you provided and after SX4 write PM 1,309. Regards, Harendra Kumar |
The Following User Says Thank You to hiiibdh For This Useful Post: |
