mxkey team how to solve this prb..- WD timer enabled, phone will reboot itself after hello mxkey team plz help it solve this prob plz tell me any soloution this fault Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35193903150381-0 Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351939031503810 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
repair sd then write rpl pm.............. |
DO YOU A NEW USER OF MXKEY...........THERE IS SO MUCH TREAD HAS TALK ABOUT YOUR PROBLEM........ FOR EXAMPLE...: http://forum.gsmhosting.com/vbb/showthread.php?t=920409 |
use latest version 3.3rev1.4 then read all pm then backup rpl then click repair sd in imei and security then after successfull reparing of sd go to pm tab then edit the readed pm of your unit uncheck all adress only pm1 and pm309 are in check then click super sd atuh then write pm done.... |
just follow these STEPS:: 1. open: service> imei & security> REPAIR SD(if DONE proced to atep 2) 2. open: PM> SUPER SD 3. tick LOAD FROM FILE (select PM 1 and 309 area only) 4. tick WRITE when PM writing is DONE to check if phone is OK, tick again BUS CHECK for your PM file: http://www.megaupload.com/?d=6BAMQH0I |
tested and working sucefull repaired a 6120c and e63. thanks |
i have also repaird 6500c but it also doing this problem when i check it shows every thing is ok. but it turns of after 10 min some time 20 some time 30 like this i have the RPL back file before i unlock and repair the phone... should i need to write it back and then start again or i shod do the SD repair and write pm and next \ ?????? |
Repair SUPERDONGLE procedure next please spend your time for reading this thread [MXKEY - TIPS] MXKEY in practice - What you should know about mobileEx - br, |
