Old 10-09-2010, 10:59   #1 (permalink)
Registered User
Member: 557525
Thanks Meter: 67
Red face rh-93 1110i unlock solve
econdaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 008D1D5A:2984DA60
ASIC type: 2
UEM Imei: 35364401476854
Flash Imei: 35364401476854
MasterCode: 4163544011
RPL saved to "C:\mobileEx\3.4\data\backup\35364401476854_BACK.r pl"
Phone Type: RH-93
SW Version: V 5.53 20-07-06 RH-93 (c) NMP
Imei plain: 35795700384303-4
Product Code: 0532991
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: AD
Language Pack:
English,French,German,Turkish
Imei net: 35795700384303
Version:
Counter: 0/3, 0/10
CONFIG_DATA: D43D4E221930AB88
PROFILE_BITS: 59D2F5B3450117B9
SIMLOCK_DATA corrupted!
problem solve pls?
Old 10-09-2010, 11:18   #2 (permalink)
Registered User
Member: 557525
Thanks Meter: 67
Imei net: 353644014--------
Version:
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: 0000000000010000
BLOCK 1: 1.CORRUPTED
Updating SIMLOCK ...Error 1
Calculating SIMLOCK RPL using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3
Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-93_35364401476854_SIM.RPL"
Updating SIMLOCK ...ERROR: 01
Reading Simlock info ...
Imei net: 3536440147---------
Version:
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF thıs solve ?????????????????
Old 10-09-2010, 12:49   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
erase eeprom:
- get addr, untick safe erase, select eeprom.
- repair sl, direct (rsa method)
- write pm, skip simlock part.
- full factory
The Following User Says Thank You to gbluez For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.13632 seconds with 9 queries
