02-19-2010, 07:34 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | mxkey team pls help mxkey ver.3.2 rev5.4 Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008D66BC:2984DA60 ASIC type: 2 UEM Imei: 35135500417363 Flash Imei: 35335500417363 MasterCode: 2462456662 Invalid imei checksum ! Phone Type: RH-30 (Nokia 3200) SW Version: V 5.34 11-02-05 RH-30 3200 (c) Nokia Imei plain: ??????????????-? Imei OTP: 35135500417363 Product Code: 0511995 Cellular System: GSM ASIC ID: 0x1130, type: 2 Ppm Id: A Language Pack: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Counter: 0/3, 0/10 CONFIG_DATA: 94A9D3A31D5E2E9C PROFILE_BITS: 05A392796B857DA7 SIMLOCK_DATA corrupted! Connecting to server ...OK, Login ... ERROR=Client version outdated, please make update ! mxkey v3.3rev1.6 Phone Type: RH-30 (Nokia 3200) SW Version: V 5.34 11-02-05 RH-30 3200 (c) Nokia Imei plain: ??????????????-? Imei OTP: 35135500417363 Product Code: 0511995 Cellular System: GSM ASIC ID: 0x1130, type: 2 Ppm Id: A Language Pack: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCK SERVER VERSION 40 - Extended number of TDS-6 boxes Counter: 0/3, 0/10 CONFIG_DATA: 94A9D3A31D5E2E9C PROFILE_BITS: 05A392796B857DA7 SIMLOCK_DATA corrupted! Connecting to server ...OK, Login ... Hello C0807BF8, you have 1970 credits left. BootLoader not responding, mostly RAM problem ! |
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? | vintel | Infinity-Box | 4 | 03-07-2010 11:29 |
mxkey team pls add nokia 1202 upp 2293 unlock...... | ronygsm123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-21-2010 19:02 |
mxkey team pls help | anumobjay | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 12-24-2009 17:44 |
mxkey team pls my problem solve | TrustUnlocking™ | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-13-2009 14:01 |
mxkey team pls help | justine54 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 11-23-2009 10:17 |
