05-08-2009, 06:37 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: VietNam Age: 43
Member: 378053 Status: Offline Thanks Meter: 98 | MxKey unlock 2630 ver 6.82 with UPP ID 3168 ok tested 100% Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! PhoneType:RM-298 SwVersion: V 06.82 26-09-08 RM-298 (c) Nokia MCU file: rm298__06.82.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 4 ASIC ID: 0x3168 [-] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D2318F:3B8ADA60 Area [01000000-0101FFFF] erased in 0.571 s Area [01080000-0109FFFF] erased in 0.571 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3168 [-] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D2318F:3B8ADA60 Area [01000000-0101FFFF] erased in 0.581 s Area [01080000-0109FFFF] erased in 0.561 s Programming ... Programming completed. Completed in 1 min 6.656 s Reading Simlock info ... Imei net: 35312202296464 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
05-08-2009, 10:06 | #5 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: cebu city
Member: 126086 Status: Offline Sonork: 100.113901 Thanks Meter: 232 | tested also 100% success..thanks for the info... Quote:
The Following User Says Thank You to .:CARLO:. For This Useful Post: |
05-08-2009, 21:33 | #6 (permalink) | |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Quote:
did u check network ? | |
firmware 1680c-2b 6.82 with the upp 3168 | damvin2 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-07-2009 15:25 |
2630 mcu 6.82 downgrade & unlock ok... | ZIYAAD STRYKER | HWK | 4 | 10-06-2009 17:10 |
probleme unlocking nokia 2630 ver 6.82 | yassinek85 | J.A.F. Plus | 5 | 03-29-2009 20:37 |
How unlock 1680c ver. 6.82 | jjohn5646 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 02-23-2009 05:20 |
Here is 2600c rm-340 with ver 6.82 | kailash_gm | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 02-03-2009 12:47 |
