Old 06-16-2010, 08:52   #151 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
Thanks to Alim for this great and hard Work .........
Good work mxkey team we hope for more update ........... but we need paid update for SL3 unlocking....
Thanks
Old 06-16-2010, 08:56   #152 (permalink)
faisal4friend's Avatar
Member: 262523
Sonork: 100.1611482
Thanks Meter: 288
failed to read sp data new version mxkey dct4 bug plzz fixed it
Old 06-16-2010, 09:22   #153 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
Originally Posted by shakeel145 View Post
we can flash 1616 1208 this update as a ATF interface
if u have atf then y u think flash by 1616?
1616 will support mx , now not supported,
Old 06-16-2010, 09:24   #154 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
Originally Posted by pavi View Post
PLZ ANYBODY HELP ME.. WHEN I"M USING USB MODEM IF I WANT USE GO TO SUPPORT AREATHEN GIVEN ERROR...(Could not connect to server, please check connection or firewall !)..
SO PLZ TELL ME HOW DISABLE FIREWELL...
disable antivirus then try , post result
Old 06-16-2010, 09:36   #155 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
its mean the mx-key team not leave their project good news
but we need add like some 5130 and others for repair its CS
and still the 2610b not flashed with mx-key when its dead during flash
Old 06-16-2010, 09:46   #156 (permalink)
..::\/\/::..'s Avatar
Member: 1294131
Sonork: 16919899
Thanks Meter: 579
thankes sir good post
Old 06-16-2010, 09:47   #157 (permalink)
Member: 263982
Sonork: kc
Thanks Meter: 2
pls i flash nokia 7210c whit mxkey and it enter contact service, pls what can i do now??
Old 06-16-2010, 10:16   #158 (permalink)
twentyonecell's Avatar
Member: 664744
Thanks Meter: 156
X3-RM 540
Using device: AdvanceBox Turbo Flasher
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x]
ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
ROM ID: 67E82268F29CEA60
Custom loader not available for this ID ! ?????????
Restarting phone ...
RAP Data :
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 09F000120A540E4948BFF6F2336CC7A73742A6A6
ASIC MODE ID: 00
 SecondaryBoot: RAP3Gv40_2nd.fg [BB5]  version: 9.50.0 revision: 2.1 size: 0x3BC0
 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
TransmissionMode: DDR&TX2
FlashID0: 0000 0000  - 0000 0000 [unused/removed] type: NOR,RAP
FlashID1: 0000 0001  - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 00EC 0030  - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP
 Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6]  version: 9.50.0 revision: 2.1 size: 0x7E41B
RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35200804064138
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35200804064138_BACK.rpl"
Processing file: rm540__04.11.mcusw as MCU
 [BB5,XSR 1.6]  size: 25.92 MB
 Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100
RAP Data :
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 37.69 MB
CMT MuxOneNAND area [00020000-000203FF]
CMT MuxOneNAND area [00060000-0009FFFF]
CMT MuxOneNAND area [000A0000-0025FFFF]
CMT MuxOneNAND area [003E0000-005DFFFF]
CMT MuxOneNAND area [005E0000-010DFFFF]
CMT MuxOneNAND area [01EC0000-01EDFFFF]
CMT MuxOneNAND area [027C0000-02CBFFFF]
CMT MuxOneNAND area [077C0000-07B3FFFF]
CMT MuxOneNAND area [010E0000-01EBFFFF]
Format Partition ...
Flash programming ...
CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written.
Programming completed in 16.890 s
Processing file: rm540__04.11.ppm_x as PPM
 [BB5,XSR 1.6]  size: 7.62 MB
RAP Data :
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
Partitioning ...OK
Erase size: 8.87 MB
CMT MuxOneNAND area [01EE0000-027BFFFF]
Programming completed in 5.000 s
Processing file: rm540__04.11.image_x_0581106_001 as CNT
 [BB5,XSR 1.6]  size: 13.19 MB
RAP Data :
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
Partitioning ...OK
Erase size: 75.06 MB
CMT MuxOneNAND area [02CC0000-077BFFFF]
Programming completed in 8.625 s
Flashing completed in 2 min 28.125 s
Phone Type: RM-540 (Nokia X3-00)
SW Version: V 04.11 09-12-09 RM-540 (c) Nokia
Imei plain: 35200804064138-0
Product Code: 0581264
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 352008040641380
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 2 min 45.172 s
FULL FACTORY... Failed!
Completed in 8.718 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.609 s
Custom loader not available for this ID !==
a red mark on his problems exist where
Old 06-16-2010, 10:17   #159 (permalink)
pepe67's Avatar
Member: 568492
Thanks Meter: 230
Thanks team for update!
Old 06-16-2010, 10:36   #160 (permalink)
Member: 1146881
Thanks Meter: 19
MANOLE very very thanks atf add to interface.
we want imei 12134656 repair and sl3 unlock
thanks
Old 06-16-2010, 10:40   #161 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
yes nice update, please one day add bb5box by raskal is useless nowday,
Old 06-16-2010, 10:44   #162 (permalink)
A-H-T's Avatar
Member: 36394
Thanks Meter: 250
great update , now i can use ATF as interface
2 things i noticed this time , one i like the other i dont.
1st the application does not need signing , which is better
2nd JAF interface name is still POTATO Flasher , which i hoped it will be renamed back to JAF , coz this is a professional tool and need to act professionally . consider this in mind
E65 flashed in 3:50 seconds
this error i dont know what is it , the cable is fine, maybe bug , but the phone flashed sucessfully and working
wbr,
Old 06-16-2010, 10:45   #163 (permalink)
imam's Avatar
Member: 82846
Thanks Meter: 29
Good politic...Nice move Mxkey Team!!
Br,
Old 06-16-2010, 10:55   #164 (permalink)
Member: 642363
Thanks Meter: 49
thanks for nice update ..now team again start working....
Old 06-16-2010, 10:58   #165 (permalink)
Member: 170684
Thanks Meter: 19
what about sl3 unlock, I hope mxkey can do this.
thanks for update.
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.23850 seconds with 11 queries
