Old 02-01-2012, 05:22   #1 (permalink)
Member: 533010
Thanks Meter: 16
Nokia 3110 contect service pls help me
MXKEY LOG
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0853E81
Using device: HTI, FW ver: 00.24, SN: 0000341B
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 13600203E8BD7E56C8B2857F19D6A7A04AC30F5D
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Original Imei: 35322503484410
Original Product code: 0581437
Bluetooth ID: 002547AD3D49
Phone type: RM-237 (Nokia 3110c)
SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35322503484410-6
Battery voltage: 4221 mV, current: 65 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
Imei net: 353225034844106
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
Old 02-01-2012, 05:30   #2 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
lol... search bro!
too lazy??
check here then:
http://forum.gsmhosting.com/vbb/f550...ailed-1214364/
good luck bro
br
The Following User Says Thank You to specta For This Useful Post:
Old 02-01-2012, 05:36   #3 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 96
ur simlock also failed........so if u have backup then write otherwise u have to buy new rpl for it.
The Following User Says Thank You to unuunu For This Useful Post:
Old 02-01-2012, 05:39   #4 (permalink)
dharmeshslnk's Avatar
Member: 385162
Thanks Meter: 598
1st repair simlockdata
after repairing simlock you need to write full pm with sx4..
The Following User Says Thank You to dharmeshslnk For This Useful Post:
Old 02-01-2012, 05:47   #5 (permalink)
SANWER's Avatar
Member: 581945
Sonork: 100.1601426
Thanks Meter: 62
it is 100% solution. please do it. get result.
Old 02-01-2012, 05:54   #6 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
it is easily solved by mxkey with one click, no need back up file at all it is not sl3 bro
br
Old 02-01-2012, 06:10   #7 (permalink)
Member: 533010
Thanks Meter: 16
Same problem bro.
Product code: 0514950
Battery voltage: 4258 mV, current: 67 mA
Language Pack:
- not available.
SIMLOCK invalid!
Counter: 0/3, 0/10
The Following User Says Thank You to rajkamal_kasdol For This Useful Post:
Old 02-01-2012, 06:17   #8 (permalink)
Member: 533010
Thanks Meter: 16
Battery voltage: 4256 mV, current: 67 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 02-01-2012, 06:18   #9 (permalink)
Member: 533010
Thanks Meter: 16
Security test failed
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Using cached productData.
PRIVATE ID: C38A4F24FEC0E8B1AA7C3EAF66B64C78E92678B3
Updating SIMLOCK...error 0x1
Reading Simlock info ...
Counter: 0/3, 0/10
Old 02-01-2012, 10:15   #10 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. dont misguide as phone is sl2 & no need to buy rpl, only repair simlock of update simlock is ok for your kind information.
Page generated in 0.23975 seconds with 9 queries
