01-07-2012, 19:54 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | N82 Bus check Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0xxxxxx Using device: HTI, FW ver: 00.50, SN: 0000xxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 0DDBBA80D30B7C9EF7E11EDF5D918C357FB30A26 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 12300010358600587329141EAD58CB41506246C1 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 Storage0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,NAND, asic:APE S***ested algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED Original Imei: 3589xxxxxxxx Original Product code: 0558580 Bluetooth ID: 001DFD8A812D WLAN ID: 001DFD7E4C2D SIMLOCK PA identifier: [0] PA_SL2 Phone type: RM-313 (Nokia N82) SW version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia Imei plain: 3589xxxxxxxxxx Product code: 0553740 Battery voltage: 4523 mV, current: 218 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3589xxxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
01-08-2012, 01:57 | #7 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1210083 Status: Offline Thanks Meter: 6 | here is log for dct4 phone with eazy cable NOKIA 1208 SW version: V 5.06 12-01-08 RH-105 (c) NMP Imei plain: 35351902XXXXXX Product code: 0550584 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IC Language Pack: English,Arabic,French,Swahili Master code: 0744301303 Imei net: 3535190XXXXX Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
01-08-2012, 01:59 | #8 (permalink) |
Member: 1210083 Status: Offline Thanks Meter: 6 | Here log for the same phone with fbus nokia 1208 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: XXXXXXX Using device: HTI, FW ver: 00.24, SN: XXXXXX Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Boot error: CC CC CC 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. |
01-08-2012, 02:01 | #9 (permalink) |
Member: 1210083 Status: Offline Thanks Meter: 6 | Here log for BB5 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: XXXXXXX Using device: HTI, FW ver: 00.24, SN: XXXXXX Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Bootstrap failed! |
01-08-2012, 02:05 | #11 (permalink) |
Member: 1210083 Status: Offline Thanks Meter: 6 | It's works fine befor, for now deos not please manol we are payed your MX box make ufs woked for your user who have mx box until you solve this problem cause we can't work now, |
The Following User Says Thank You to HAAAH For This Useful Post: |
01-08-2012, 04:53 | #14 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | new version of mobileex, will not work on OLDER box firmware. must use FW 00.50 and above. Quote:
please download here http://forum.gsmhosting.com/vbb/f550...hread-1410959/ BR | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
