12-30-2009, 13:04 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: INDIA
Member: 566051 Status: Offline Thanks Meter: 105 | n 73 sim not valid ----------------------- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 0F41634844C7B6C5B9E023B2CA92B324656838C4 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 23800107E096465009C2374B2435127C3F4F0A07 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Original Imei: 35897301443475 Original Product code: 0543843 Bluetooth ID: 001DFD06DE9B Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v60.1 20-03-08 RM-133 (c) Nokia. Imei plain: 35897301443475-3 Product Code: 0529607 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed "RM-133" folder created. Imei net: 358973014434753 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
12-30-2009, 13:06 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
check red marked ... unlock it or repair data | |
The Following User Says Thank You to alamgarh For This Useful Post: |
12-30-2009, 13:09 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: india
Member: 573120 Status: Offline Thanks Meter: 145 | first try to repair sl area then unlock it or write good pm if needed with sx4 if still same then restore backup , because ur config data and profile is ffffffffffffffffffffffffffffffffff . |
12-30-2009, 13:18 | #6 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Quote:
Just use this method it should be done if not try to use zulea's not TP unlocker should be done. br. | |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
12-30-2009, 13:28 | #8 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | thanks to all member .set is ok after update sim lock ------------------------------log here------------------ Imei net: 358973014434753 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Backup saved to "BB5_358973014434753_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot(0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.3\data\backup\358973014434753_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 24.813 s Restarting phone ... Reading Simlock info ... Imei net: 358973014434753 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
n 73 sim not valid help me | jubin8255 | Nokia Hardware & Hardware Repair | 5 | 03-29-2010 08:33 |
nokia n 73 sim not valid | Robin Telecom | Nokia Hardware & Hardware Repair | 3 | 10-14-2009 17:46 |
N95 when insert sim it show sim not valid what is solution reply the post as | ashwani gupta | Nokia Base Band 5 ( BB-5 ) | 7 | 11-10-2008 00:54 |
china sim not valid or sim cad rgistration faild | classic mobiles | Chinese Models & Cloned Phones | 15 | 07-05-2008 14:40 |
Nokia 1112 Sim Not Valid Not Imei Zero | Danu_in | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-05-2008 07:31 |
