10-22-2010, 07:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan Age: 41
Member: 616556 Status: Offline Thanks Meter: 112 | N1112 Can,t Rebuild IMEI (answered) SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00881405:2984DA60 ASIC type: 2 UEM Imei: 05410201458484 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\05410201458484.RP L" ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00881405:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ...failed Phone Type: RH-93 SW Version: V 6.00 24-10-06 RH-93 (c) NMP Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 00000000000EFFB8 PROFILE_BITS: 0003562036013030 SIMLOCK_DATA corrupted! |
10-22-2010, 09:01 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 55
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | ASIC type: 2 UEM Imei: 05410201458484 here may be your problem UEM damaged |
The Following User Says Thank You to neilthirumuttam For This Useful Post: |
10-22-2010, 10:47 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | damaged OTP data. you will need new uem to fix the phone. - install new uem - calculate rpl data as desired imei + asic version. - write rpl by using file from calculated rpl above. |
The Following User Says Thank You to gbluez For This Useful Post: |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
