05-07-2010, 11:29 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: gorontalo
Member: 629228 Status: Offline Thanks Meter: 17 | repair imei ?????????? 7610-rh51 success...with 3.4 rev 1.0 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00CC1320:2984DA7E ASIC type: 5 UEM Imei: 356965014***** SERVER->Served by MXKEY - BLADE X at host1, agent version 1.0 revision 1.6 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\356965014*****.RP L" ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 00CC1320:2984DA7E Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RH-51 (Nokia 7610) SW Version: V 2005_wk21 27-05-05 RH-51 (c) Nokia. Imei plain: 356965014*****-* Product Code: 0514521 Cellular System: GSM ASIC ID: 0x1081, type: 5 Language Pack: - not available. Imei net: 356965014***** Version: SIMLOCKLIB VERSION 2.29 Counter: 0/3, 0/10 CONFIG_DATA: B238DA4402FF8467 PROFILE_BITS: E8D5B136DF63FD36 SIMLOCK_DATA corrupted! Imei net: 356965014***** Version: SIMLOCKLIB VERSION 2.29 Counter: 0/3, 0/10 CONFIG_DATA: B238DA4402FF8467 PROFILE_BITS: E8D5B136DF63FD36 SIMLOCK_DATA corrupted! Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 356965014***** Version: SIMLOCKLIB VERSION 2.29 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000005 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following 4 Users Say Thank You to naurah For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
