12-09-2009, 19:54 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: BD/HAIL KSA
Member: 1001269 Status: Offline Thanks Meter: 226 | n73 after flash 3-5 min turn off plz help SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35863401714849-9 Product Code: 0529785 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei: 358634017148499 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
12-09-2009, 20:12 | #4 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Mumbai Age: 43
Member: 523792 Status: Offline Thanks Meter: 96 | Quote:
The Following 2 Users Say Thank You to DIN231080 For This Useful Post: |
12-10-2009, 05:37 | #13 (permalink) |
Junior Member Join Date: Dec 2008
Member: 914598 Status: Offline Thanks Meter: 1 | try with jaf box with ufc cable and try to force the software click in BB5 and select the next "Manual Flash" and "INI" only that. Next you will see all the model select the model with RM-133 and put flash ( if you donīt have a ufc cable try with the fbus cable but is more possible you can revive the this phone) pd. if work donīt forget give thanks |
The Following User Says Thank You to roberto-terraza For This Useful Post: |
01-04-2010, 15:53 | #15 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | Not a rpl bro your phone imei ok and super dongle invalid u solve by other tools with logs hope mx-key new update solve this |
Sigmatel fxd t33i , after first incoming call, no backlight off, plz help | nakshatra | Infinity-Box | 11 | 06-03-2010 07:31 |
5310 after flash only nokia then switch off pls help | krishnaaruna | Nokia Hardware & Hardware Repair | 4 | 03-25-2010 16:04 |
se w850 after flash still on white light blinking plz help me | neeraj1st | SETool2 | 5 | 02-24-2010 07:52 |
6131 after show nokia turn off plz help | asif_ae | Nokia Hardware & Hardware Repair | 5 | 07-02-2009 09:38 |
D600, after flashing lcd light not turn off | Sezamek | NSPRO | 5 | 06-03-2006 00:24 |
