n73 dead mxkey help when i click bus check option of mxkey show this log what's problem plz solution want not set flash Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 5E7DA66F7405DD9649DA56FECA01585BB9672927 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 1B00010393940154E84ECC8A575310E15E377BFB ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 ID 32: 000110040050 TransmissionMode: 16Bit Flash ID not supported for this loader (RAP3Gv3_algo.fg) Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 loader not responding (0400000000B172) |
loader not responding (0400000000B172) maybe incorrect loaders path..... |
Phone Die Check by MX-key Not Ok MCU + PPM + CTN => Flash |
try usb flash and post result :) |
The main problem is, program not load flash loader correctly / phone not ready to boot (not synchronized correctly between program and phone). Unplug your phone - connect again - Restart Program |
brother use usb cable maybe it can be solved |
Flash ID not supported for this loader (RAP3Gv3_algo.fg) phone missing flash cmt h/w problem |
this is the problem i am getting for last two updates i tried and searched i could not find any solution i got the ATF it works without any problem thank s to ATF |
Bro it is ok not hardware problem just flash on it jaf it ll be ok BR, |
