Old 08-31-2013, 12:13   #1 (permalink)
Member: 174094
Thanks Meter: 74
n73-1 prob
get n73 rm-133 return to seller
flash it with high version ok but light on keypad non off & lcd still black
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0821955
Using device: HTI, FW ver: 00.50, SN: 01014D94
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013)
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 17E39A5578778C7A3EA065C30569C5AA79EA8EFA
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 21E0011996E46A50DF84C63915CC6577C5A62878
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Storage0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: FLASH,NAND, asic:APE
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Processing MCU file: N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx
[BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 46.93 MB
Supported Ids: 17100708
Partitioning ...OK
Erase size: 91.38 MB
CMT FLASH,NOR area [00080000-0073194D]
CMT FLASH,NOR area [00000000-0005FFFF]
CMT FLASH,NOR area [001E0000-001FFFFF]
CMT FLASH,NOR area [00880000-00FEFFFF]
erased in 35.520 s
Prog.status for Asic CMT ...
NOR: OK
NAND: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 5E8D0D50 [Rap Certificate 26 v1] sent
CMT UPDAPP block sent
CMT ADL block sent
CMT DSP0 block sent
CMT MCUSW block sent
APE KEYS block sent
APE X-LOADER block sent
APE PRIMAPP block sent
APE SOS+LOADER block sent
APE SOS*UPDAPP block sent
APE SOS+UZIP block sent
APE PAPUBKEYS: 5E8D0D50 [Ape Certificate 26 v1] sent
APE PASUBTOC block sent
APE ADL block sent
APE SOS+XZIP block sent
APE SOS*CORE block sent
APE SOS+ROFS block sent
APE SOS+ROFX block sent
Prog.status for Asic APE ...
NOR: OK
NAND: OK
Programming completed in 1 min 46.322 s
Processing PPM file: N73_rofx_4.0850.43.0.1_PRD.V77
[BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 17.07 MB
Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000
Supported Ids: 17100700, 17100701, 17100702, 17100708
Partitioning ...OK
Erase size: 21 MB
erased in 0.288 s
NOR: OK
NAND: OK
NOR: OK
NAND: OK
Programming completed in 47.961 s
Processing CNT file: N73_userarea_4.0850.43.0.1.U03
[BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 5.12 MB
Erase size: 46.50 MB
erased in 0.633 s
NOR: OK
NAND: OK
NOR: OK
NAND: OK
Programming completed in 10.661 s
Total time for flashing process(boot+erase+write) was 3 min 27.246 s
Phone type: RM-133 (Nokia N73)
SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia.
Imei plain: 35956801537505-1
Product code: 0529790
Battery voltage: 4888 mV, current: 83 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359568015375051
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
& here's selftest log
Phone Type: RM-133
ID Test name Startup Result
88 TAHVOINT Y passed
46 UEM_CBUS_IF Y passed
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
90 PWR_KEY N passed
2 CURRENT_CONS N passed
20 BACKUP_BATT N passed
58 CMT_APE_WAKEUP N !no signal
56 SLEEPCLK_FREQ N passed
42 RADIO N passed
96 HOOKINT N passed
101 BTEMP N passed
49 VIBRA N passed
8 MBUS_RX_TX_LOOP Y !no signal
108 EXT_DEVICE N passed
any idea
Old 08-31-2013, 14:54   #2 (permalink)
diyong's Avatar
Member: 1883757
Thanks Meter: 37
what problem before of your unit sir? try to hard reset the phone..
2nd step need to downgrade firmware and flash it
Old 09-17-2013, 17:12   #3 (permalink)
Member: 579284
Thanks Meter: 6
re
flash the phone hwk or jaf
Old 09-17-2013, 17:34   #4 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,670
Remove smps and make jumper
http://1.bp.********.com/_Keh96gcwLj...svCkU/s400/n73 smps.jpg
Page generated in 0.16908 seconds with 8 queries
