05-18-2011, 07:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | N73 Phone Start up failed Contact Retailer (ANSWERED) before operation Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35765201625578-5 Product Code: 0539295 Battery voltage: 4791 mV, current: 95 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 357652016255785 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F after operation Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35765201625578-5 Product Code: 0539295 Battery voltage: 4415 mV, current: 258 mA ApeCoreSw: V 4.0839.42.2.1 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357652016255785 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-18-2011, 07:36 | #3 (permalink) |
Banned Join Date: Mar 2007 Location: BALAJI TECHNOLOGIES Age: 38
Member: 462076 Status: Offline Sonork: 100.1586314 Thanks Meter: 307 | contact me on [email protected]. i will help u bro |
05-18-2011, 07:58 | #4 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Bro...... its a simple repair or update "sim lock" your poblem 10000000000% solved................................... Br, Aniaxn |
05-18-2011, 08:19 | #5 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | Quote:
The Following User Says Thank You to r-jcomm For This Useful Post: |
05-18-2011, 11:34 | #7 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Bro........just do...... your phone is off...... press together.....*+ call +3 key and on the phone...............your problem will be 1000000000% solved............. Br, Aniaxn |
The Following 2 Users Say Thank You to AniAxn For This Useful Post: |
03-11-2012, 10:09 | #8 (permalink) |
Registered User Join Date: Nov 2009 Location: pakistan
Member: 1151975 Status: Offline Sonork: 100.1615809 Thanks Meter: 6 | i have n73 in problem phone start fail contect retailar log is here Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0850.43.0.1 Imei plain: 35765201142605-0 Product code: 0539295 Battery voltage: 4119 mV, current: 249 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Phone version(4.0850.43.0.1) outdated, latest version on server is: 4.0839.42.0.1 Imei net: 357652011426050 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F SW version 4.0839.42.0.1 released for Nokia N73 |
03-11-2012, 10:11 | #9 (permalink) |
Member: 1151975 Status: Offline Sonork: 100.1615809 Thanks Meter: 6 | when sim lock repair log here Imei net: 357652011426050 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C085406A Using device: HTI, FW ver: 00.50, SN: 00002D7E Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012) Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Using cached productData. PUBLIC ID: 0850020800D2675094C008343955E203FD9BABA3 PRIVATE ID: 0FCBDC68DDBA24E58AC2054A4FE33543102464B1 Updating SIMLOCK ...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
03-11-2012, 10:28 | #10 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
then there 2 options u can try to solve simlock: go to tab service>imei&security> tick on Init simlock, click update splock or go to tab service>imei&security> tick on unlock by code, click calc nck good luck bro br | |
03-11-2012, 15:01 | #11 (permalink) |
Freak Poster Join Date: Nov 2008 Location: bhilai(chatisghar)
Member: 900306 Status: Offline Thanks Meter: 36 | TRYING TO RECOVER CERT BUT [InternalErrorFault] CERT [0543843] data not available for this phone (case id=0xCE01) PROBLEM IS Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35354802141121-1 Product code: 0539692 Battery voltage: 4693 mV, current: 0 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353548021411211 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
03-11-2012, 17:51 | #12 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | @ biswajit74 >load pm 1 & 309 >click "repair sd" >now dont allow software to write pm from its local cache. press "write" to write ur uploaded pm. thats all |
03-11-2012, 21:50 | #13 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
on most case, one click repair SD should be done. | |
03-12-2012, 07:34 | #15 (permalink) | |
Member: 900306 Status: Offline Thanks Meter: 36 | Quote:
Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35640601211798-1 Product code: 0539354 Battery voltage: 4698 mV, current: 0 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356406012117981 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN after sd repiar MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0802E17 Using device: HTI, FW ver: 00.50, SN: 0000D080 Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011) Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0850.43.0.1 Using cached productData. PUBLIC ID: 1AF001183DCF0154E9AAE9FFB9538920F2051CFB PRIVATE ID: BC54684469B37720CF61A71E68E143F88DDB2608 Updating SUPERDONGLE_KEY ...OK Authenticating to SUPERDONGLE ... SUPERDONGLE authorized ! Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\N73_RM-133.txt ... Writing RF settings to phone ...OK, finished. 20 Records found. Writing BB settings to phone ...OK, finished. 9 Records found. Done. but... same problem..... i have 2 handset in my hand but having same problem any soluation............. | |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
