Old 10-27-2010, 05:53   #1 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
n73 phone startup failed #solved, closed, old thread
i have n73 with startup failed
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Imei plain: 354851020xxxxx-x
Product Code: 0539691
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
Imei net: 354851020xxxxxx
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
After write pm when repair splock show this
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Using cached productData[2390011173A44F50C7894290B8F086C8026DE210] ...
Calculating SIMLOCK using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3
Completed in 2.953 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-133_354851020xxxxxx_SIM.RPL"
Updating SIMLOCK...
error 0x1
Reading Simlock info ...
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
where is the problem help me
The Following User Says Thank You to sr8787 For This Useful Post:
Old 10-27-2010, 07:36   #2 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
try to rapeir sim lock with rpl
problem solve
rana is best
Old 10-27-2010, 07:56   #3 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Updating SIMLOCK...[COLOR="Red"]error 0x1[/COLOR this one main problem
Old 10-27-2010, 08:15   #4 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
but your block r all open after unlock ... then what is your problem
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post:
Old 10-27-2010, 08:33   #5 (permalink)
babloojaved's Avatar
Member: 890104
Sonork: 100.1597567
Thanks Meter: 138
1. backup RPL(just in case).
2. erase EEPROM.
3. Repair SD
4. SUPER SD Auth + Write PM1,309
just do it i have tested
erase EEPROM only Flash -> advance -> Get address
untick safe erase.
tick eeprom area only
DO "ERASE"
all do all Repair SD, pm 1 & 309, Simlock
your phone will be ok
just thanks
The Following 6 Users Say Thank You to babloojaved For This Useful Post:
Old 10-27-2010, 08:43   #6 (permalink)
عمادالعمده's Avatar
Member: 903681
Thanks Meter: 28
and sim luck [IMG][/IMG]
Old 10-27-2010, 10:27   #7 (permalink)
Raznet's Avatar
Member: 564325
Thanks Meter: 104
try this method bro for that :http://forum.gsmhosting.com/vbb/f550...olved-1108511/
Old 10-28-2010, 10:35   #8 (permalink)
Member: 890104
Sonork: 100.1597567
Thanks Meter: 138
Cool N73 phone startup failed [Answered]
Originally Posted by Raznet View Post
Why such type or risky job "erase phone & flash back" if any thing goes wrong your phone will die
just do this command and your problem will be solved
I have tested it
2. erase EEPROM.
3. Repair SD
untick safe erase.
DO "ERASE"
The Following User Says Thank You to babloojaved For This Useful Post:
Old 10-30-2010, 20:39   #9 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
2. erase EEPROM.
3. Repair SD
untick safe erase.
DO "ERASE"
thanks bro it works for me
Old 11-03-2010, 14:05   #10 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
when i am try to repair simlock ith show this msg
Updating SIMLOCK...error 0x1
and when Scan all ok
SIMLOCK seems to be valid
SIMLOCK_TEST passed
and when bus chek show this again
Imei plain: 35485102072260-7
Product Code: 0545033
Language Pack:
- not available.
SIMLOCK invalid!
Imei net: 354851020722607
Counter: 0/3, 0/10
Old 11-03-2010, 18:37   #11 (permalink)
Member: 1158839
Thanks Meter: 127
2. erase EEPROM.
3. Repair SD
untick safe erase.
DO "ERASE"
just thanks
work 100000% tested by me
Old 11-03-2010, 22:50   #12 (permalink)
Member: 1005417
Sonork: 100.1603146
Thanks Meter: 8
has been discussed a lot in trying to find just...
Old 02-12-2011, 21:03   #13 (permalink)
amit kanpur's Avatar
Member: 1033905
Sonork: amitsharma
Thanks Meter: 892
Arrow
1. Backup rpl(just in case).
2. Erase eeprom.
3. Repair sd
4. Super sd auth + write pm1,309
erase eeprom only flash -> advance -> get address
untick safe erase.
do "erase"
all do all repair sd, pm 1 & 309, simlock
just thanks
thanks tested solution
Old 10-05-2011, 07:54   #14 (permalink)
Member: 1090178
Thanks Meter: 3
my problam solved by mxkey ido just update splock & write pm ,autharized from superdongle
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.27626 seconds with 9 queries
