06-14-2012, 16:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | N73 problem SIMLOCK invalid This is the Scan Log Phone type: RM-133 (Nokia N73) SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35291602969830-6 Product code: 0539295 Battery voltage: 4873 mV, current: 91 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 352916029698306 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F SW version 4.0839.42.0.1 released for Nokia N73 After Clicking on Repair SIMLOCK shows this error Imei net: 352916029698306 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F MXKEY [OMNIKEY AG Smart Card Reader USB 0], SN: C08056ED Using device: HTI BOX, FW ver: 00.07 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Phone type: RM-133 (Nokia N73) SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Boot error: 00 00 00 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Reading Simlock info ... |
06-14-2012, 17:03 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. This happens some times when Data Erased in Simlock Section of PM. It's Simlock Invalid but my Method is like Security Test Failed & doesn't Matter but. So Backup RPL & as now you have to write Full PM, direct upload & write will failed to write Secure Area, so try my Method, Go to Service Tab>Upload any saved Full RM-133 PM>Click Repair SD>Click No to Pop Up Window for RFBB, now Click Write>Click Yes to Pop Up Window for Area 308. Again go to IMEI & Security>Simlock>Tick Repair Simlock>Click Repair SP Lock, Click Buscheck & will see Positive Result. Have a good day. BR, Zuber Chowdhry |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
