09-11-2012, 12:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: MUMBAI Age: 53
Member: 41672 Status: Offline Thanks Meter: 195 | N73 Security Test Failed recover cert error [InternalErrorFault] CERT [0543843] data not available for this phone (case id=0xCE01) |
09-14-2012, 18:26 | #7 (permalink) |
No Life Poster Join Date: Apr 2011 Location: kerala
Member: 1550704 Status: Offline Sonork: 100.1644808 Thanks Meter: 248 | http://forum.gsmhosting.com/vbb/f550...ailed-1534166/ its working 100% with me......... use to same methad... |
10-02-2012, 12:10 | #8 (permalink) |
Member: 41672 Status: Offline Thanks Meter: 195 | not working with me Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out |
10-02-2012, 15:54 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Why need SX4 Card when HTI Box Stanalone, Use this Method, Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-133.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER |
10-02-2012, 17:35 | #10 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | If you are not able to solve Security test failed even after writing pm with sx4. Then most probably your RPL certificate like hwc and ccc is corrupted. This error can be solved by Recover Cert. function in MXbox. But N73 dosent have HWC and CCC instead it has Variant data. To repair this problem we need a working N73, and just Read it's full RPL Now open the RPL in notepad you will see various lines like NPC, Simlock data and Variant. Just select all the lines of Variant and copy it. Now make a new text file and paste the Variant in it and save it as Variant.rpl. Now write this RPL to your faulty phone and your problem should be solved. |
10-04-2012, 09:35 | #11 (permalink) | |
Member: 41672 Status: Offline Thanks Meter: 195 | Quote:
try it but same recover cert getting error | |
10-08-2012, 15:09 | #15 (permalink) |
Freak Poster Join Date: Mar 2008 Location: india
Member: 719527 Status: Offline Thanks Meter: 8 | MT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0CC001173F83005852D67D1EE834DACCB379E109 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Report Post Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post! Reply With Quote |
