12-03-2012, 12:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: IN INDIA
Member: 263005 Status: Offline Thanks Meter: 147 | n73 security test failed SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 3--------------- Product code: 0---- Battery voltage: 4915 mV, current: 37 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3---------- Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN test result Phone Type: RM-133 SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. ID Test name Startup Result 88 TAHVOINT Y passed 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N !failed ! 90 PWR_KEY N passed 2 CURRENT_CONS N passed 20 BACKUP_BATT N passed 58 CMT_APE_WAKEUP N !no signal 56 SLEEPCLK_FREQ N passed 42 RADIO N passed 96 HOOKINT N passed 101 BTEMP N passed 49 VIBRA N passed 8 MBUS_RX_TX_LOOP Y !no signal 108 EXT_DEVICE N passed |
12-03-2012, 13:02 | #2 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | 1.first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory reset your phone must come back from security test failed it is 100% tasted by me. wbr ; tejaram |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
12-04-2012, 16:49 | #3 (permalink) | |
Member: 263005 Status: Offline Thanks Meter: 147 | Quote:
12-04-2012, 16:50 | #4 (permalink) |
Member: 263005 Status: Offline Thanks Meter: 147 | Phone Type: RM-133 SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. ID Test name Startup Result 88 TAHVOINT Y passed 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N !failed ! 90 PWR_KEY N passed 2 CURRENT_CONS N passed 20 BACKUP_BATT N passed 58 CMT_APE_WAKEUP N !no signal 56 SLEEPCLK_FREQ N passed 42 RADIO N passed 96 HOOKINT N passed 101 BTEMP N passed 49 VIBRA N passed 8 MBUS_RX_TX_LOOP Y !no signal 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 85 CDSP_TX_IQ N passed 74 CDSP_TXC_DATA N passed 82 CDSP_PWR_DETECTOR_BIAS N passed 79 CDSP_RX_PLL_PHASE_LOCK N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 75 CDSP_WCDMA_TX_POWER N !unknown(14 0) - 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal |
