02-06-2010, 12:42 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | n73 superdongel ok but secourity test faild how to solve? Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.609 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_12345610654321-_SD.RPL" Updating SUPERDONGLE_KEY ...OK Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0543843 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-12 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Phone authenticated to SUPERDONGLE already. know my phone is at phone startup failed contact the retailer |
02-06-2010, 13:01 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: UNITED ARAB EMIRATES Age: 41
Member: 760274 Status: Offline Thanks Meter: 146 | Imei plain: 12345610654321-? dear check your imei dear if you have backup rpl just restore it. or you need bb5 rpl if not wait for mx key next update may be manole make rpls service soon... |
02-06-2010, 13:55 | #6 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
MXKEY can repair this kind problem if your get reseting IMEI what problem ? can u post with details info , may with log. br, | |
02-06-2010, 14:02 | #7 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | my handset show s super key invalid and wd timer on iamd imei is 123456...?, i try to repair super dongel ke sucessfull repiar but secourity test fail and my handset go contact retailer i write pm from another handset and then write only pm 1 and 309 after then my handset gone to phone start up faild before this my handset log's logPhone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 12345610654321-? Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-06-2010, 14:09 | #8 (permalink) |
Member: 271008 Status: Offline Thanks Meter: 280 | after using this methode my handset gone phone startup failed. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here:Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0543843 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-06-2010, 14:11 | #9 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: namo buddhaya,namo amithaba...
Member: 169781 Status: Offline Thanks Meter: 14 | Quote:
The Following User Says Thank You to sufianto_0202 For This Useful Post: |
02-06-2010, 18:15 | #10 (permalink) | |
Freak Poster Join Date: May 2008 Location: gujarat ind
Member: 773986 Status: Offline Thanks Meter: 52 | Quote:
hone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0529607 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED help | |
03-26-2010, 17:47 | #13 (permalink) |
Junior Member Join Date: Nov 2008
Member: 899842 Status: Offline Thanks Meter: 4 | sir, Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0B2002025F4F7A5655D8E36E45A555708EBEEDBD ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Original Imei: 35983001495322 Original Product code: 0549247 Bluetooth ID: 001EA3EC4ADB Phone Type: RM-272 (Nokia 3500c) SW Version: V 07.21 05-11-08 RM-272 (c) Nokia. Imei plain: 35983001495322-5 Product Code: 0549248 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359830014953225 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF what problem my phone please healps argent thanks |
03-28-2010, 15:30 | #14 (permalink) |
Member: 899842 Status: Offline Thanks Meter: 4 | sir 3500c self test Phone Type: RM-272 SW version: V 07.21 05-11-08 RM-272 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO Y passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 56 SLEEPCLK_FREQ N passed 101 BTEMP N passed 107 BT_SLEEP_CLK N !no signal 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 85 CDSP_TX_IQ N !no signal 74 CDSP_TXC_DATA N !no signal 79 CDSP_RX_PLL_PHASE_LOCK N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal |
I how to solve this problem | Saulcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-30-2010 10:02 |
security test failed how to solve | newtouch | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-05-2010 13:15 |
N85 Phone start up failed sim lock test failed how to solve it?? | alasdro | Nokia Base Band 5 ( BB-5 ) | 7 | 12-14-2009 18:29 |
samsung t209 show unlock ok , but phone still locked, why and how to solve? | svchost | NSPRO | 3 | 10-31-2009 13:09 |
