03-06-2010, 13:14 | #1 (permalink) |
Junior Member Join Date: Feb 2007
Member: 455244 Status: Offline Thanks Meter: 0 | need help 1202 upgrade.. MCU SW version: V 04.03 29-06-09 RH-112 (c) Nokia HW version: 1000 UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_09w22_U LCD version: WIN:SERI:8a NT7542 PPM version: ,D0 pb rl p N :L ( 4 ADSP SW version: p no NAI version Product Info: Production serial number: DMZ249001 Product code: 0562283 Module code: 0203762 Basic production code: 0558505 Serial Numbers: IMEI plain: 353195033049322 IMEI spare to net: 3A 35 91 05 33 40 39 02 IMEI SV to net: 33 35 91 05 33 40 39 12 F9 Other Info: CS type : GSM/DCS1800 BSI: 4.6 KOhm Imei net: 35319503304932 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN kindly tell me what m doing wrong and how to fix this problem cell phone dont display aanything after nokia logo .. thnx plz m newbie @flashing thnx |
03-06-2010, 21:11 | #3 (permalink) |
Member: 455244 Status: Offline Thanks Meter: 0 | Using device: J.A.F, FW ver: 01.B0 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C68 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0008CFFFA3BDA66 ASIC type: 11 UEM Imei: 35319503304932 Flash Imei: 35319503304932 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35319503304932_BA CK.rpl" Processing file: rh112_003.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C68 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0008CFFF:2984DA60 Area [01000000-0100FFFF] erased in 1.422 s Area [01010000-013AFFFF] erased in 1 min 20.656 s Area [013B0000-013EFFFF] erased in 5.719 s Area [017C0000-017EFFFF] erased in 0.062 s Area [01FC0000-01FEFFFF] erased in 0.063 s Flash programming ... Programming completed in 16.391 s File Processed in 1 min 56.125 s Processing file: rh1120_nai03.00ij as CNT [DCT4,DCT4 ALGORITHM] size: 167.28 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C68 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0008CFFF:2984DA60 Area [01380000-013AFFFF] erased in 4.235 s Flash programming ... Programming completed in 1.234 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.172 s File Processed in 27.203 s Processing file: rh112_003.00ij as PPM [DCT4,DCT4 ALGORITHM] size: 1.07 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C68 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0008CFFF:2984DA60 Area [01240000-0124FFFF] erased in 1.422 s Area [01250000-0137FFFF] erased in 26.782 s Flash programming ... Programming completed in 7.734 s File Processed in 47.781 s Flashing completed in 4 min 3.062 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RH-112 SW Version: V 03.00 14-11-08 RH-112 (c) NMP Imei plain: 35319503304932-2 Product Code: 0569782 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IJ Language Pack: - not available. Imei net: 35319503304932 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! Total time to process is 4 min 32.640 s plz tel me now what m doing wrong !! thnxxxx im doing 1st time in life plz any comment any suggesttion will be welcome |
03-07-2010, 11:19 | #5 (permalink) |
Member: 455244 Status: Offline Thanks Meter: 0 | Imei net: 35319503304932 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! PhoneType:RH-112 SwVersion: V 03.00 14-11-08 RH-112 (c) NMP MCU file: rh112_003.000 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C68 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0008CFFF:2984DA60 Area [01000000-0101FFFF] erased in 2.828 s Area [01160000-0117FFFF] erased in 2.766 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x14 my set was not locked it was okey i bought mxkey yesterday so iwas trying it .. . but no body is helping me here .. !~! |
03-07-2010, 11:25 | #6 (permalink) |
Member: 455244 Status: Offline Thanks Meter: 0 | Phone Type: RH-112 SW Version: V 03.00 14-11-08 RH-112 (c) NMP Imei plain: 35319503304932-2 Product Code: 0546861 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: EL Language Pack: - not available. Failed to read SP data |
Need help to upgrade 6131 v3.70 | sebaelpotro | BB5BOX | 4 | 04-02-2008 22:15 |
need help to upgrade | mobilom | SagMaster Team OLD Products | 1 | 04-01-2007 11:51 |
Need help in upgrading firmware in 3650 | Ismail Samah | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-01-2005 10:04 |
hasp drivers ..i need help after upgrade | lufabbiu | FuriouS II | 2 | 04-04-2005 07:52 |
need help in upgrading a sl 42 to a sl 45i | sl42_2_sl45i | x1x to x45/x50 | 2 | 06-28-2003 09:10 |
