Old 02-22-2010, 08:51   #1 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
1600 imei ?
any one do the change of imei of the 1600 set
here is log
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 0095078A:2984DA60
Trying to find patch position ...Ok, found in 11.438 s
Not supported firmware.
Error while processing command !
Old 02-22-2010, 08:58   #2 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
with uncheck patch software option
here is log
ASIC type: 2
UEM Imei: 35365001748072
Flash Imei: 35478765867654
Writing new imei ...
New imei written.
Phone Type: RH-64
SW Version: V 5.53 20-07-06 RH-64 (c) NMP
Imei plain: ??????????????-?
Product Code: 0525376
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: IA
Language Pack:
English,Arabic,Farsi,French,Urdu
Imei plain is invalid !!!
Imei net: FFFFFFFFFFFFFF
Version:
Counter: 0/3, 0/10
CONFIG_DATA: E2443EAD5B4694B6
PROFILE_BITS: 3E1213184400CD3A
Imei net is empty, process aborted.
the imei is corrupted now
Old 02-22-2010, 08:59   #3 (permalink)
Cyclone Team<3's Avatar
Member: 1212935
Sonork: cylone team
Thanks Meter: 122
just use online logger,..
Old 02-22-2010, 09:03   #4 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
now the imei change successfully but the signals gone after 30 secands
here is log
ASIC type: 2
New imei written.
Phone Type: RH-64
Imei plain: 35365001748072-9
Ppm Id: IA
Language Pack:
Imei net: 35365001748072
Version:
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Updating SIMLOCK ...OK
any one test with perfect solution
Old 02-22-2010, 09:03   #5 (permalink)
realtech's Avatar
Member: 1003310
Thanks Meter: 28
Pls check your uem imei and the imei backside the phone is same or not?
Old 02-22-2010, 09:08   #6 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
i need to change it and i already done but signals gone after some time
Old 02-22-2010, 09:11   #7 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
1110 <---------------- RH-70<---------------0526-------------------V5.03,V5.53,V6.40
1112 <---------------- RH-93<---------------0502,0526,0536-------V5.03,V5.50,V6.40
1112B<----------------RH-92<---------------2201------------------V5.03
1600 <---------------- RH-64<---------------0526,0529<------------V5.53,V6.00,V6.40
1600B<----------------RH-65<---------------0529 <-----------------V5.03
2310 <---------------- RM-189<--------------0526,0531<------------V3.31,V5.10,V5.90 ,V6.30
2610 <---------------- RH-86<---------------0601 <----------------V3.77,V5.23, 5.65
2626 <---------------- RM-291<--------------2002,2502,0501,0601,<---V 03.51,V4.61
2630 <---------------- RM-298 <--------------1001,2000 <-----------V3.82,V5.20
2760 <---------------- RM-259 <-------------- 2503 <-----------V03.62
3220 <---------------- RH-37<---------------5053,6203 <-----------V03.30,v5.90
5070 <---------------- RM-167<--------------4012 <----------------V4.20
6020 <---------------- RM-30<---------------5001,5051 <----------------V 04.90,V5.20
6030 <---------------- RM-74<---------------0702 <----------------V4.11,V511
6080 <---------------- RM-166<--------------4051 <----------------V4.22
6101 <---------------- RM-77 <--------------5000 <----------------V3.38
6103 <---------------- RM-162<--------------4006 <----------------V4.61
match ur id this is important.if u want to repair u must know about match id
Old 02-22-2010, 09:12   #8 (permalink)
realtech's Avatar
Member: 1003310
Thanks Meter: 28
i dont understand you already replaced uem or not? reply
Old 02-22-2010, 09:28   #9 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
dear this list work with ub only not with this because the hd id is not shown when you bus check the any dct4 any how ma phone in this hd id
RH-64<---------------0526 with supported version
Old 02-22-2010, 09:32   #10 (permalink)
Member: 405696
Thanks Meter: 148
ur imei stolen block hahahahahah 35365001748072-9 this imei is stolen block theft imei
change ur imei brother its 100% ok
sorry for laughing
Old 02-22-2010, 09:45   #11 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
sorry for laughing
1st of all i m will not mind for you extra teeth shake
2ndly please please read the previously post care fully
3rd i think you will laugh on your self
Old 02-22-2010, 09:51   #12 (permalink)
Member: 36715
Thanks Meter: 22
good answer for all such creeps
Old 02-22-2010, 09:59   #13 (permalink)
Member: 405696
Thanks Meter: 148
ur imei stolen block 35365001748072-9
if not block i leave forummmmmmmmmmmm check ur imei brother and me also write sorry.
this imei block pta. so just change imei ur problem solve
Old 02-22-2010, 10:00   #14 (permalink)
Member: 405696
Thanks Meter: 148
and this is gift how check imei is block or not
http://128.121.21.25/$sitepreview/pta.gov.pk/imei/imei.asp
write this in ur browser
Old 02-22-2010, 10:05   #15 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
oh you hell poster i know very well
whats pro with you yes yes i need that to change
please do not disturb
help 1600 imei ????????????.. Rinaldo UFS2 + UFS3-Tornadoflasher 4 12-03-2010 19:41
1600 imei ????? someone calculate my 1600 julmars Phone Unlocking Codes & Maps 2 04-26-2009 03:58
nokia 1600 imei jacob magembe Nokia Digital Core Technology 4 ( DCT-4 ) 2 09-16-2006 12:07
1600 imei ????????4 Rinaldo UFS2 + UFS3-Tornadoflasher 6 04-28-2006 10:52
Page generated in 0.26511 seconds with 9 queries
