N85 only nokia logo Can someone help me on nokia n85 rm333 i flash it sucessful and format factory setting..even test all security and passed but still in nokia logo..hw to fix this???br |
chang flat cabel ...... |
flash the eno part. BR |
cabel flix ....................... |
SW Version: V ICPR72_08w44.1 10-11-08 RM-333 (c) Nokia Imei plain: 35570802504003-0 Product Code: 0577607 ApeCoreSw: 11.047 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355708 Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23433F BLOCK 2: 1=OPEN, DATA=23486F PLS WHICH IS ENO PART??BR |
have you flash your phone with configuration like this (just example) http://i50.tinypic.com/nnk19k.jpg Software first, if still the same, you can start to check the flex cable. BR |
brother this problem hardwaer chang flix cable |
MCU SW version: V ICPR72_08w44.1 10-11-08 RM-333 (c) Nokia HW version: 1400 RFIC version: Vapaus_5.1 ??? DSP version: ICPR72_08w44 APE SW Core version: 11.047 APE Variant version: 11.04711.047.005.1 APE Test version: RM333_ENO_x_2009wk03v41 Retu version: 16 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 WLAN Id: : 00 F3 8B D8 FC 22 Product Info: Production serial number: CSE633005 Product code: 0577607 Basic production code: 0560428 Long production SN: 0 Serial Numbers: IMEI plain: 355708025040030 IMEI spare to net: 3A 55 07 08 52 40 00 03 IMEI SV to net: 33 55 07 08 52 40 00 03 F3 Other Info: Model : Nokia N85 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA II/WCDMA VIII BSI: 4.8 KOhm Imei net: 3557080sion: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23433F BLOCK 2: 1=OPEN, DATA=23486F NOT CABLE ISSUE IT READ PHONE DETAILS VERRY WELL EASY GOING LOCAL MODE..BR |
yes br thanx this i mean Quote:
yes br this i mean flexible cable |
