07-06-2012, 09:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | GPG UFC 2012 need assistence to use mxbox i also ask for the power adapter for the GPG UFC what voltage that it use? i need to unlock with my N73-1 |
07-08-2012, 03:17 | #5 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | i have try to unlock my N73-1 please let me know what correct to connect the GND & BSI to phone and also where to i connect the pin to the phone board |
07-08-2012, 03:26 | #6 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | i need help here? after update » Begin transaction ... Initializing HTI ... HTI initialized. Boot version: 01.09 Serial: 0xxxxxxxx Receive firmware from server ... SERVER->MXKEY - BLADE Z at upd, agent version 1.2 revision 0.3 Firmware version on server: 00.50 changes: added: boot mode switch function improved: serial and flash bus communication routine added: dct4 product data calc algorithm added: broadcom sec.repair algorithm minor bug fixed. Received buff checksum verified OK. Waiting for HTI in boot mode ... Reinitializing HTI ... Updating HTI firmware, please WAIT ... HTI firmware update OK. » End transaction (status: 0, Successfull) Waiting HTI in application mode ...Done. |
07-08-2012, 04:50 | #9 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Using device: HTI PLUS Flasher Interface Connection status: UHCI:HUB:USB 2.00 Full-speed WARNING: Device drivers might not work properly ! [err0] required OHCI(1.1)/EHCI(2.0)/xHCI(3.0) controller, connect your device to a different USB port ! Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 180D1313620B4E533A8E564B020000F5 Boot ver: 01.09, Box SN: 0xxxxxxx FW version: 00.50 HTI PLUS Flasher Interface ready. i have change to different usb port but error still appears |
07-08-2012, 05:54 | #10 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Please help with this error try to unlock my N73-1 Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] BLOCK2: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: Cxxxxxxx Using device: HTI, FW ver: 00.50, SN: 0xxxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012) Phone type: RM-133 (Nokia N73) SW version: V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 9CDFD427F6E13830EC3D7B8B897AC4437514E7CE ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 0740010ADBA401542D1AE298C2F0C10BA4486CF7 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 ERROR: Configuration request failed ! Unknown ID ! Error getting boot info ! ERROR: bootstrap failed! Reading Simlock info ... Imei net: 353xxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] BLOCK2: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] |
07-08-2012, 06:47 | #13 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
the above log where the same way that i try to unlock it but you check the log it give error on it eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 ERROR: Configuration request failed ! Unknown ID ! Error getting boot info ! ERROR: bootstrap failed! | |
07-08-2012, 07:33 | #14 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | i have an error and need to know what that error //connected HTI PLUS Flasher Interface Using device: HTI PLUS Flasher Interface Connection status: UHCI:HUB:USB 2.00 Full-speed WARNING: Device drivers might not work properly ! [err0] required OHCI(1.1)/EHCI(2.0)/xHCI(3.0) controller, connect your device to a different USB port ! Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 180D1313620B4E533A8E564B020000F5 Boot ver: 01.09, Box SN: xxxxxxxxxx FW version: 00.50 HTI PLUS Flasher Interface ready. //Bus Check ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 ERROR: Packet Error(0xAA), code 0x4A000001 |
07-08-2012, 21:15 | #15 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Phone success fully unlock this morning Phone type: RM-133 (Nokia N73) SW version: V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. Imei plain: 35xxxxxxxxxxxxxxxx Product code: 0539397 Battery voltage: 4657 mV, current: 36 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35xxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] BLOCK2: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] Imei net: 35xxxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] BLOCK2: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0873A97 Using device: HTI, FW ver: 00.50, SN: 010089EB Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012) Phone type: RM-133 (Nokia N73) SW version: V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. Using cached productData. PUBLIC ID: 0740010ADBA401542D1AE298C2F0C10BA4486CF7 PRIVATE ID: E640D20376439F86F91419D4FFDC088B6CBB620A Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35xxxxxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
