11-17-2009, 19:03 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 50
Member: 72341 Status: Offline Thanks Meter: 7 | N90 only nokia help ! Version from phone: 05wk07v28 Version from file: RM42.C0 Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.10913, Date: 05-11-2009 Read Certificate failed. NPC_DATA is empty. RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to ".rpl" Processing file: 5060773_RM42.C0 as MCU [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 31.35 MB Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported APE Ids: 17100701, 17100702 Bootstrap failed! Flashing terminated with error(s) in 1 min 11.797 s RX Buffer: |
11-17-2009, 19:41 | #3 (permalink) |
Member: 72341 Status: Offline Thanks Meter: 7 | same with ufs : Version from phone: 05wk07v28 Version from file: RM42.C0 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 Boot error: 02 FF 72 00 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Read Certificate failed. NPC_DATA is empty. RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to ".rpl" Processing file: 5060773_RM42.C0 as MCU [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 31.35 MB Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported APE Ids: 17100701, 17100702 Boot error: 02 FF 72 00 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Bootstrap failed! Flashing terminated with error(s) in 1 min 7.890 s RX Buffer: |
11-17-2009, 21:07 | #4 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ::::...I LOVE PAKISTAN...::::
Member: 823250 Status: Offline Sonork: 100.1587800 Thanks Meter: 187 | bro fist chek ur cable and flash wid latest version.....if problem not solve then uninstall ur mxkey setup and also delete ur mx key folder from c: drive then install mx key setup again......then flash it ak |
Nokia n73-1 after flash only nokia logo. Please help ! | Unlocker_001 | HWK | 16 | 03-07-2013 07:10 |
nokia 1208 only nokia disply and stope plz helpe meeee | kashig | Nokia Hardware & Hardware Repair | 5 | 01-09-2010 13:43 |
6233 Only Nokia.....Help | snisar | Nokia Hardware & Hardware Repair | 4 | 09-11-2009 15:27 |
6600 only nokia help me | shivam4you | Nokia Hardware & Hardware Repair | 7 | 08-06-2009 13:55 |
help experts nokia 6680 only nokia logo | rippysingh | Nokia Hardware & Hardware Repair | 9 | 06-15-2008 12:26 |
