Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011)
Remove USB cable from device.
Turn off the phone
Press and hold down key 'u'
Connect USB cable between the phone and host PC while still holding down key 'u'
When USB cable gets connected it powers the phone and set's it to flashing mode
SW version in image: RX-51_2009SE_20.2010.36-2_PR_MR0
Image 'kernel', size 1705 kB
Version 2.6.28-20103103+0m5
Image 'rootfs', size 185728 kB
Version RX-51_2009SE_20.2010.36-2_PR_MR0
Image 'cmt-2nd', size 81408 bytes
Version BB5_09.36
Image 'cmt-algo', size 519808 bytes
Version BB5_09.36
Image 'cmt-mcusw', size 5826 kB
Version rx51_ICPR82_10w08
Image '2nd', size 14720 bytes
Valid for RX-51: 2217, 2218, 2219, 2220, 2120
Version 1.4.14.9+0m5
Image 'xloader', size 14848 bytes
Image 'secondary', size 109440 bytes
Valid for RX-51: 2101, 2102, 2103
Image '2nd', size 14848 bytes
Valid for RX-51: 2307, 2308, 2309, 2310
Valid for RX-51: 2407, 2408, 2409, 2410
Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306
Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406
Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119
Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506
Valid for RX-51: 2607, 2608, 2609, 2610
Valid for RX-51: 2507, 2508, 2509, 2510
Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216
Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606
USB device found at bus-0, device address
\\.\libusb0-0001--0x0421-0x0105.
Found device RX-51, hardware revision 2101
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_20.2010.36-2.206.1_PR_206
Sending xloader image (14 kB)...
Sending secondary image (106 kB)...
Flashing bootloader... done.
Sending cmt-2nd image (79 kB)...
Sending cmt-algo image (507 kB)...
Sending cmt-mcusw image (5826 kB)...
Flashing cmt-mcusw... done.
Sending kernel image (1705 kB)...
Flashing kernel... done.
Sending and flashing rootfs image (185728 kB)...
Finishing flashing... done
CMT flashed successfully
