09-01-2012, 01:07 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: heLL and beY0nd
Member: 281801 Status: Offline Sonork: 100.1608672 Thanks Meter: 158 | You need emmc file to Reset phone Lock in this phone. No tools currently in the market can read or unlock the code. Current EMMC for RX-51 "RX-51_2009SE_10.2010.13-2.VANILLA_PR_EMMC_MR0_ARM". Search for file and flash with Maemo Flasher. |
09-01-2012, 09:36 | #5 (permalink) | ||
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Your Phone is Nokia N900 & supported USB Flashing, no need FBus. Quote:
Already Meamo support in Mxkey Apps. You can Flash it with Mxkey. BR, ZUBER | ||
09-01-2012, 10:09 | #7 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi Bro. Download complete Flash Files including EMMC File of the same. Select Firmware from Market Drop Down Menu. Switch OFF Phone & press and hold key U, Connect USB Cable to phone. After USB Cable Connects Phone will appears in Flash Mode. Now Click Flash will remove your Phone Lock. Have a Nice Day. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
09-02-2012, 10:10 | #8 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
Using device: HTI, FW ver: 00.50, SN: xxxxxxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Remove USB cable from device. Turn off the phone Press and hold down key 'u' Connect USB cable between the phone and host PC while still holding down key 'u' When USB cable gets connected it powers the phone and set's it to flashing mode Waiting for USB device removal ... Waiting for Maemo USB device ... SW version in image: RX-51_2009SE_20.2010.36-2_PR_MR0 Image 'kernel', size 1705 kB Version 2.6.28-20103103+0m5 Image 'rootfs', size 185728 kB Version RX-51_2009SE_20.2010.36-2_PR_MR0 Image 'cmt-2nd', size 81408 bytes Version BB5_09.36 Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5826 kB Version rx51_ICPR82_10w08 Image '2nd', size 14720 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.9+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.9+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.9+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.9+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.9+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.9+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.9+0m5 Sleeping for 15 seconds while device boot up ... i stuck here now i try press 'u' when usb cable connect to pc but i can't detect it messange show that phone not respond so it need to manual. need help thanks | |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
