N95-8G Rm-421 Not Unlock? Imei: 352946024618637 Versão: SIMLOCK SERVIDOR Operadora: Tim, País: Brasil Contador: 0 / 3, 0 / 10 CONFIG_DATA: 7240200000000000 PROFILE_BITS: 0000000000000000 Bloco 1: 1 = LOCKED (MCC + MNC): 72402F, data = 72402F Bloco 2: 1 = LOCKED (MCC + MNC): 72403F, data = 72403F Bloco 3: 1 = LOCKED (MCC + MNC): 72402F, data = 72402F BLOCO 4: 1 = LOCKED (MCC + MNC): 72403F, data = 72403F Bloco 5: 1 = LOCKED (MCC + MNC): 72404F, data = 72404F BLOCO 6: 1 = LOCKED (MCC + MNC): 72404F, data = 72404F Backup já existem. Usando o dispositivo: UFS_USB V2.8 (c) SarasSoft 2007. RAÍZES chave hash: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 Enviando SecondaryBoot (0x3AC0 bytes) ... OK Enviando Preloader (0x2e4 bytes) ... OK Enviando ROM (0x11C4 bytes) ... OK Enviando SecurityBlock (0x2000 bytes) ... OK Enviando SimlockBinary (0x190 bytes) ... OK Enviando Certificado (0x1930 bytes) ... OK Cálculo de fechamento de dados ... Leitura Simlock info ... minha para essa etapa |
Help!!!!!!!!!!!!!!!!!!!!!!!!!:eek: |
Urgent n95-8g rm421 Where's MX team This is the second device that gives the same error here. I do MX team |
Imei: 352946024618637 Version: SIMLOCK SERVER Provider: Tim, Country: Brazil Counter: 0/3, 0/10 CONFIG_DATA: 7240200000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 72402F, DATA=72402F BLOCK 2: 1=LOCKED (MCC+MNC): 72403F, DATA=72403F BLOCK 3: 1=LOCKED (MCC+MNC): 72402F, DATA=72402F BLOCK 4: 1=LOCKED (MCC+MNC): 72403F, DATA=72403F BLOCK 5: 1=LOCKED (MCC+MNC): 72404F, DATA=72404F BLOCK 6: 1=LOCKED (MCC+MNC): 72404F, DATA=72404F Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x11C4 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1930 bytes) ...OK Calculating LOCK data ... Reading Simlock info ... someone has seen this or can help me? |
Must be another bug in the newer version.. Try Lower version of mx-key.. br. |
3.2 version 4x Imei: 35294602461**** Version: SIMLOCK SERVER Provider: Tim, Country: Brazil Counter: 0/3, 0/10 CONFIG_DATA: 7240200000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 72402F, DATA=72402F BLOCK 2: 1=LOCKED (MCC+MNC): 72403F, DATA=72403F BLOCK 3: 1=LOCKED (MCC+MNC): 72402F, DATA=72402F BLOCK 4: 1=LOCKED (MCC+MNC): 72403F, DATA=72403F BLOCK 5: 1=LOCKED (MCC+MNC): 72404F, DATA=72404F BLOCK 6: 1=LOCKED (MCC+MNC): 72404F, DATA=72404F Backup saved to "BB5_352946024618637_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x11C4 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1930 bytes) ...OK Calculating LOCK data ... Reading Simlock info ... HELP:confused::eek::confused::eek: |
use last version is good one,backup rpl+pm file convert to RM-320 do unlock br, |
excuse my ignorance is just making more flash with RM-320 to convert or need something more? |
convertido para RM-320, mas ainda mesmo erro Help me!!!! |
I gave up the mx-key still giving the same error. With today unlock Universal Box worked normal. vaför check this error N95 8G as is already the second here with the same error |
N95-8G not unlock update with MX-KEY I gave up the mx-key still giving the same error. With today unlock Universal Box worked normal. vaför check this error N95 8G as is already the second here with the same error :mad::mad::mad: |
