04-10-2010, 16:08 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1138285 Status: Offline Thanks Meter: 14 | n95 8gb rm-320 phone startup failed,contact retailer.very strange problem. Firstly,tick APE(skip APE),manual flash,downgrade,Fast Phone,then flash.(partial flash,Only ppm,and cnt) Secondly,untick APE(not skip APE),tick downgrade,Fast Phone,munual flash,then flash(full flash this time) It works.I can make phone call.but soon it shutdown,restart it,show me phone start-up failed.contact retailer. then I erase flash with BB5Erase_UNI_rapido.bin,flash ENO,V31,write back FULL PM and RPL. here is the MX-KEY BB5 security validation: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed And here is the log of jaf 1.98.64 Reading... MCU SW version: V 06wk41v59 22-05-08 RM-320 (c) Nokia HW version: 5151 PCI version: RFIC version: 17141715 DSP version: aino_mc.ICPR62_08w16p1 Retu version: 15 Tahvo version: 22 Production serial number: MTG838549 Product code: 0565878 Module code: Basic production code: 0548236 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 354829028909483 IMEI spare to net: 3A 45 28 09 82 09 49 08 IMEI SV to net: 33 45 28 09 82 09 49 18 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN imei is OK,I have the all the backup,JAF and MXKEY. I erase the flash with BB5Erase_UNI_rapido.bin Now I can't format the user's file system in any version(v20,v30,v31),Is it hardware fault?but before downgrading the phone is ok. Extra, now I can't get the CORRECT local mode,when get in local mode,JAF says OK,but the sreen is white.shows nothing. ::mad ::mad Sir,what's the solution? I need your help.please. best regards. |
The Following User Says Thank You to godhelpjun For This Useful Post: |
04-10-2010, 18:01 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | bro, if not work try this 1 back rpl(first backup u made) 2 full erase on mxkey 3 flash eno sw(rm320_ENO_x_2007wk45v0.020_sos.fpsx)then flash this eno too( normalize_susd_eno_aino_urel.fpsx )then flash phone with any vergn sw 4 writ rpl (first backup u made after u erase phone) 5 mxkey>serves>imei&securty>imei rebuild>repair sd 6 go to pm >click sd auth and writ pm 7 full factory |
The Following 2 Users Say Thank You to alasmmar For This Useful Post: |
04-10-2010, 19:55 | #3 (permalink) | |
Member: 1138285 Status: Offline Thanks Meter: 14 | Quote:
my jaf box used by MXKEY seems so many problems that I haven't flash a phone successfully yet.so usually I use PKEY to flash.It's perfect.but unlocking I use MXKEY,It's perfect, too. So.back to the object. I have tried exactly the procedure all you suggetted above using PKEY.but the problem is the same.(It seems all is ok,IMEI,simlock.supper_dongle...All is perfect.but it still shows me "phone startup failed...) So,there is a question here. when I flash the ENO software,it's two steps by step1 flash the SOS file and step2 flash the normalize file OR flash them all in one time? expecting for your reply(ies),sir. best regards . | |
04-10-2010, 20:31 | #4 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | 1st put this flash in mcu rm320_ENO_x_2007wk45v0.020_sos.fpsx then click flash 2st put this flash in mcu normalize_susd_eno_aino_urel.fpsx then click flash 3st flashphone normal now to slove phone startup failed mxkey>serves>imei&securty>imei rebuild>repair sd then go to pm >click sd auth and writ pm full factory and format |
The Following User Says Thank You to alasmmar For This Useful Post: |
04-11-2010, 10:07 | #5 (permalink) | |
now,the problem is the same. simlock data,IMEI,super_dongle,security...ALL IS OK.BUT still "phone startup failed,contact retailer." ::mad ::confuse | |
04-11-2010, 10:27 | #6 (permalink) | |
Freak Poster Join Date: Jan 2002 Location: Penang/Malaysia
Member: 8752 Status: Offline Thanks Meter: 26 | Quote:
bro where to get rm320_ENO_x_2007wk45v0.020_sos.fpsx ??? | |
04-11-2010, 12:37 | #7 (permalink) | |
Member: 231153 Status: Offline Thanks Meter: 313 | Quote:
04-11-2010, 12:42 | #8 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | br, u can find it here http://forum.gsmhosting.com/vbb/f550...6/#post5342436 |
04-11-2010, 14:10 | #10 (permalink) |
Member: 1138285 Status: Offline Thanks Meter: 14 | my backup rpl is here backup rpl |
04-11-2010, 14:31 | #11 (permalink) | |
upload with another | |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
